Literature Offers
01/15/2002
Metal roof
Stevens Roofing Systems highlights its EP Metal Roof Retrofit System in a 4-p brochure. The brochure lists the advantages of Stevens EP brand of thermoplastic polyolefin (TPO), illustrates several types of metal roof deck failures, and provides a step-by-step account of the retrofitting process.
stevensroofing.com
Write 316 on PE card
Material handling and storage
BCI Product line literature is available through Jarke, a designer and manufacturer of material handling and storage equipment. Jarke products include cantilever racks in several capacity ranges, modular portable storage racks, and structural pallet racking.
Jarke Corporation
jarke.com
Write 317 on PE card
Heating solutions
Watlow updates its corporate product brochure, Your Heat Solutions Resource , and profiles heaters, sensors, controllers and software. Information on Watlow's polymer technology, which can be used for freeze protection and battery heating applications, is also included.
Watlow Electric Manufacturing Company
watlow.com
Write 318 on PE card
Slip-resistant products
Trusty-Step International's complete line of slip-resistant products are showcased in the 2002 catalog. The products are designed to work on any kind of wet floor, including tile, marble, granite, cement, or wood. One treatment can last up to 5 yr and may be used indoors or outdoors.
trusty-step.com
Write 319 on PE card
Industrial products
Diversified Brands introduces an 88-p catalog detailing its industrial MRO products, including paints and coatings, lubricants, electrical cleaners/degreasers and safety solvents, caulks and sealants, applicators, and specialty chemicals.
Diversified Brands
krylonindustrial.com
Write 320 on PE card
Compressed air filters
Bulletin 199 contains information on Deltech D Series filters. The D Series features multiple ratings of four different filters: high efficiency coalescing (type CF), general purpose coalescing (type CC), particulate (type PF), and vapor removal (type VF).
Deltech
deltech-flair.com
Write 321 on PE card
Product handbook
OMEGA offers a Made in the USA edition handbook. The 3000-p handbook has more than 100,000 products and features temperature, pressure, force, flow, level, pH, conductivity, humidity, and data acquisition instruments to meet process measurement and control needs. Load cells, panel meters, controllers, recorders, thermocouples, thermistors, and connectors are also included.
Omega Engineering, Inc.
omega.com
Write 322 on PE card
Enclosures
A manufacturer of electronic enclosures, Bud Industries, Inc. publishes a Standard Products Catalog, SPC-25 for 2002. The 67-p catalog serves as a comprehensive enclosure reference guide.
budind.com
Write 323 on PE card
Butterfly valves
A technical brochure from Xomox describes Tufline high performance butterfly valves for processing industries. Close-up illustrations demonstrate the valves' sealing capabilities, including soft-seated, fire-tested, and high-temperature models.
Xomox Corporation
xomox.com
Write 324 on PE card
Lighting systems
"See the Light" is a 6-p brochure covering Stingray Lighting's patented dual-reflector lighting systems, designed for interior commercial and industrial environments, including outdoor parking lots, roadway use and high-performance flood lighting. Close-up pictures show each Stingray fixture for new construction and retrofit applications.
Stingray Lighting, Inc.
stingraylighting.com
Write 325 on PE card
Flame-resistant fabrics
Westex Inc. highlights its INDURA and INDURA Ultra Soft flame-resistant in a 20-p, full-color brochure. The fabrics are made into garments worn by workers in the electric and gas utilities, as well as the chemical, military, and ferrous metals industries.
Westex Inc.
westexinc.com
Write 326 on PE card
Dimming ballasts
Fluorescent dimming ballasts are the focus of an 8-p brochure, which provides information on the benefits of fluorescent dimming. Advance Transformer Company explains how ballasts help make dimming versatile, affordable, and easy to implement. Energy-saving strategies are also discussed.
advancetransformer.com
Write 327 on PE card
Vacuum material handling
Twenty-four pages are dedicated to Anver Corp.'s full range of vacuum-related material handling equipment, including below-the-hook lifters.
Anver Corp.
anver.com
Write 328 on PE card
Batteries and chargers
EnerSys, Inc. describes its line of long-life batteries, chargers, and accessories for electric forklift and material handling equipment. The brochure, titled "A Full Line of Lasting Power," discusses the features and benefits of the complete General Battery product line
EnerSys, Inc.
enersysinc.com
Write 329 on PE card
Conveyors for metalworking
The Metal Scrap Handling brochure provides information on the company's individual conveyors and components, which can be utilized in the machining, stamping, and die casting industries.
Prab, Inc.
prab.com
Write 330 on PE card
Hydraulic loading dock
ECOA hydraulic loading docks are featured in a brochure that includes photos, specifications, application information, and pit details for the entire series. The loading docks are designed for heavy-duty commercial and industrial truck loading/ unloading applications.
ECOA Industrial Products Inc.
ecoalifts.com
Write 331 on PE card
Test and measurement
Ideal Industries, Inc. publishes a catalog titled, "Test & Measurement Products," which covers the company's selection of digital multimeters, clamp meters, ground resistance meters, power quality testers, circuit analyzers, datacom testers, and acccessories.
idealindustries.com
Write 332 on PE card
Bulk handling
"Bulk Handling Equipment and Engineered Systems" discusses flexible screw conveyors, bulk bag dischargers, bulk bag fillers, weigh batching systems, batching/blending systems, volumetric feeding conveyors, manual dumping stations, and automated plant-wide systems.
Flexicon Corporation
flexicon.com
Write 333 on PE card
