Literature Offers
Calibration TTI presents a 76-p Calibration Catalog, featuring temperature, pressure and signal calibrators. The publication also looks at the expansion of TTI's product line, as well as the complete line of new laboratory-grade signal calibrators. TTI, Inc. ttiglobal.com Circle 316 Space solutions Solving space needs is the theme of PortaFab's brochure, and the company utilizes photographs...
08/01/2001
Calibration
TTI, Inc.
ttiglobal.com
Circle 316
Space solutions
Solving space needs is the theme of PortaFab's brochure, and the company utilizes photographs and illustrations to guide the reader. Among the spotlighted items is the Type 3 beam-to-column connection, the most stable design on the market for maximum strength and performance.
PortaFab Corp.
portafab.com
Circle 317
Valves
Red Valve's updated brochure contains information on new products, as well as application and installation options. The core product line is also reviewed within the pages.
Red Valve Co., Inc.
redvalve.com
Circle 319
Scissors Lift
The West Bend Equipment Division of Bushman Equipment, Inc., introduces a Scissors Lift Technical Data Sheet. The brochure provides an overview of the West Bend platform lift line, and the wide-ranging applications of the various models.
West Bend Equipment
westbendequipment.com
Circle 318
Thermometers
A 28-p catalog by Tel-Tru Bimetal Thermometers contains product information designed to make specification easy. The manufacturer offers its thermometers in a wide range of configurations and ranges.
Tel-Tru Manufacturing Co.
teltru.com
Circle 320
Vehicle systems
A full-color brochure highlights the full line of Automated Guided Vehicles (AGV), including unit load, fork-type, towing, and low-profile vehicles. Control Engineering Co., a subsidiary of the Jervis B. Webb Co., provides the AGV material handling solutions.
Jervis B. Webb Co.
jervisbwebb.com
Circle 321
Flowmeters and software
Barnant offers flow-rate analysis software and full specifications on the Gilmont flowmeter line in 16-p, full-color catalog. The expanded line of flowmeters is designed for industrial and laboratory use.
Barnant Co.
barnant.com
Circle 322
Gear reducers
Specifications and order instructions for the LeCENTRIC series, Leeson's line of inline gear reducers, are displayed in a full-color, 84-p catalog. LeCENTRIC units are designed with modular mountings to match the footprint of other popular reducer brands, including SEW, Nord, David Brown, Dodge and Brook-Hansen, the maker says.
Leeson Electric
leeson.com
Circle 323
Compressors
Kaeser Compressors, Inc., offers a 4-p, catalog featuring its compressors and compressor air equipment, including filters and drain traps. The catalog also lists size ranges for rotary screw and piston compressors, aftercoolers, and dryers.
Kaeser Compressors Inc.
kaesercompressors.com
Circle 324
Utility cards
ACCES I/O Products unveils its new line of PCI-Bus data acquisition cards, utility cards and accessories in a 56-p, PCI I/O catalog. Products detailed include two data acquisition system models, five digital-to-analog converter models, and eleven digital I/O models.
ACCES I/O Products
acces-usa.com
Circle 325
Accessories
A 100-p catalog details thousands of products geared toward a wide range of design and test requirements from high-density chip leads to hard-to-reach industrial test points. Products for the telecommunications test industry are included.
Pomona Electronics
pomonaelectronics.com
Circle 326
Flowmeters
ISTEC Corp's mini catalog showcases the newest flowmeters, Btu meters, chip card systems and flowguards. The catalog is offered at no charge to professionals.
ISTEC Corp.
istec-corp.com
Circle 327
Fuses
A 96-p guide by Bussmann showcases more than 1850 fuses and accessories for semiconductor protection and includes fuse categories such as North American, British, European (DIN) and Ferrule. In the product and category sections, comparison charts aid in quickly locating the desired fuse, size, and electrical characteristics. Dimension schematics, total clearing 12t, arc voltage, and power losses are typical data included.
Cooper Bussmann
cooperindustries.com
Circle 328
Mobile monitor
Gray Wolf presents its mobile computer-based monitor, the DirectSense IAQ, in a brochure. The monitor is designed to collect more reliable and more detailed indoor environmental quality information. Temperature, relative humidity, carbon dioxide, carbon monoxide and air velocity can be displayed and data-logged.
Gray Wolf Sensing Solutions
WolfSense.com
Circle 329
FACTS manual
The 114-p, updated FASTENER FACTS manual by Barnes Distribution is a resource for mechanical engineers and end users. Highlighted areas include cap screw assemblies, socket screws, hex nuts and tapped holes and flat washers and locking devices.
Barnes Distribution
barnesgroupinc.com
Circle 330
Pressure relief valves
Farris Engineering, a division of Curtiss-Wright Flow Control Corp., introduces a brochure on Series 2700 pressure relief valves, which are designed to meet exacting demands of process industries. Conventional and balanced design pressure relief valves are discussed, in addition to SME Code certification, construction materials, and optional O-ring seat design for maximum seat tightness.
Farris Engineering
cwfc.com
Circle 331
Dust collector
Wheelabrator Air Pollution Control Inc. presents JET III Pulse Jet Dust Collectors, a brochure that includes illustrations, photographs and sizing charts. JET III's technology is offered in custom and pre-engineered designs and aimed at meeting specific needs across various applications.
wapc.com
Circle 332
