Literature Offers
Network grounding systemsA 60-p catalog covers copper and mechanical grounding components for network applications. The publication provides features, benefits, and complete specifications, including materials, dimensions, sizes, part numbers, and illustrations. Information charts and a cross-reference guide are included in the literature.
Staff
Panduit Corp.
panduit.com
Circle 316
Uninterruptible power systems
A 6-p foldout brochure describes the MD Series uninterruptible power systems. The UPS is used with linear or nonlinear load applications, including LAN/WAN, telecommunications, and industrial controls. The brochure lists features and benefits, proven field solutions, and a selection guide.
Controlled Power Co.
controlledpwr.com
Circle 317
Wheels
New 36-p industrial catalog features polyurethane and rubber-on-iron wheels in sizes up to 20 in. 3 5 in. Additional product lines include forged steel, semi-steel, solid polyurethane, and specialty wheels. Photos, technical information, and product specifications are included in the catalog.
Trew Industrial Wheels, Inc.
trew-wheels.com
Circle 318
Wire and cable
New catalog details thousands of types of electrical/electronic wire, cable, and cord products. Specifications, engineering data, construction, and usage information are provided.
American Insulated Wire Corp.
aiwc.com
Circle 319
Fluid control equipment
Product Digest offers a wide range of fluid control equipment, such as process control valves, on-off valves, pressure-reducing valves, regulators, steam water heaters, actuators, and controllers.
Leslie Controls, Inc.
lesliecontrols.com
Circle 320
Roller bearings
Imperial mounted spherical roller bearings are the topic of a new 6-p brochure. The literature details the features and benefits of the Imperial adapter system as it applies to IP and ISAF mounted roller bearings. Photos and drawings demonstrate the features of the bearings.
Rockwell Automation
dodge-pt.com
Circle 321
Knobs and handles
This new 40-p catalog takes the guesswork out of selecting the proper knob or handle for each application. The publication features hundreds of styles, colors, sizes, and materials.
Davies Molding
daviesmolding.com
Circle 322
Air filtration
A 16-p catalog provides provides an overview of air filter systems, equipment, and capabilities. Features, benefits, and application guidelines are included for nearly 50 product lines. The catalog covers two primary application areas: comfort air and clean processes.
Camfil Farr
camfilfarr.com
Circle 340
Shock control
Brochure describes products and services offered to control shock, vibration, and structure-borne noise.
Fabreeka
fabreeka.com
Circle 323
Handrails
A 48-p catalog describes handrails and fittings designed for ease of installation, flexibility, and strength.
The Hollaender Mfg. Co.
hollaender.com
Circle 324
High-speed label system
The LRU Less Ribbon Used Print and Apply system prints labels on demand and simultaneously affixes them to products, boxes, cartons, etc., as they pass on a conveyor belt. A 4-p brochure provides an overview of the system and lists specifications.
QuickLabel Systems
quicklabelsystems.com
Circle 325
Luminaires
Lyon Series luminaires are detailed in new literature. The fixtures create a well-illuminated environment with lower-wattage lamps and fewer luminaires. Lamps are available in high-pressure sodium, metal halide, and mercury vapor; wattages of 35%%MDASSML%%175 W.
Holophane
holophane.com
Circle 326
Oil mist collectors
A 12-p brochure describes Machine Master oil mist collectors. Technical information is provided for this five-cell, continuous duty source-capture system for the containment of oil, coolant mist, and vapor pollutants.
The Uni-Wash/Polaris Industrial Ventilation Group
unipol.com
Circle 327
Variable transformers and electrical connectors
Free 16-p product guide is a useful reference on variable transformers and electrical connectors. Powerstate variable transformers include single and three-phase motorized types from 0.13%%MDASSML%%365 kVA, open and closed construction, portable with or without meters, 40 V, and special duty models.
Superior Electric
superiorelectric.com
Circle 328
Footwear
Safety footwear is featured in a new 52-p catalog. The publication features men's and women's protective and occupational footwear in a wide range of styles and materials.
Hytest Safety Footwear
hytest.com
Circle 329
Floor care equipment
A new catalog details a full line of floor care equipment and coatings, plus a line of outdoor cleaning machines. Product information, selection guide, and suggested applications are included in the 16-p guide.
Tennant Co.
tennantco.com
Circle 330
Safety products
Keeping workers safe from head-to-toe is made easier with this new 676-p product catalog. Fall protection, protective clothing, hearing protection, respirators, first aid, labels, and other products are featured in the comprehensive catalog. A reference section offers valuable safety resources, glossary, and more.
Lab Safety Supply
labsafety.com
Circle 331
Bar code label printer
The Top-Hand QLS-500 bar code label printer is described in a 4-p brochure. The printer offers 304-dpi lithographic printing, TrueType scalable fonts, high-speed 10-in./sec throughput, and 5-in. print width. The literature contains specifications and available options and accessories.
QuickLabel Systems
Circle 332
Low-profile conveyors
A 16-p catalog provides specifications for the low-maintenance 2220 Series of low-profile conveyors., The conveyors are available in flat belt end drive, cleated belt end drive, and flat belt center drive models. Standard size and ordering infromation, along with special features and benefits for each conveyor model, are listed.
Dorner Manufacturing Corp.
dorner.com
Circle 333
Skin care
A Guide to Understanding Skin Problems in Industrial Workplaces is an 8-p brochure about occupational skin disorders, primarily focusing on contact dermatitis. The brochure details causes of the skin disorder, and outlines preventive measures. Skin cleanser options and skin care systems are discussed in the literature.
Kimberly-Clark Corp., Skin Wellness Institute
kcskinhealth.com
Circle 334
Motors
New 2001 industrial motors catalog features small, medium, and large ac and dc stock, standard, and nonstock motors, with ratings from fractional to 1500 hp. Photos, mounting dimension charts, ratings, available modifications, and more are featured in the 278-p catalog.
Reliance Electric/ Rockwell Automation
reliance.com
Circle 335
Instruments
A 24-p catalog highlights more than 250 new instrumentation items. Products include miniature dataloggers, wireless RF transmitters, and a wide range of portable instruments.
APT Instruments
aptinstruments.com
Circle 336
Sensors
New 500-p catalog provides product information and specifications for a wide range of sensor products.
Balluff
balluff.com
Circle 336
Lifter
The Mobile Tri Lifter works like a gantry, crane, or forklift; and can move heavy loads in confined spaces. The unit's low profile allows it to fit through an 8-ft 3 10-ft door. Working as a gantry it can lift 100 tons to 24 ft, 9 in.; as a crane or forklift, capacity is 75 tons. A brochure describes how the machine operates in its three modes and provides details on load capacities, maneuverability, and safety features. Specifications for turning radius, load limits at different operating heights, overall dimensions, and weight are also provided in the literature.
Riggers Manufacturing Co.
riggers.com
Circle 337
Personal protective equipment
Pocket-sized brochure describes a line of personal protective equipment. The brochure features eye, head and face, hearing, and respiratory protection product lines.
Dalloz Safety
cdalloz.com
Circle 338
Automation consulting
New brochure describes the company's automation consulting and project management services. The 6-p piece explains how a team follows a project throughout its life cycle, which can include evaluation and assessment, process system design, planning and specification, integration and implementation, and maintenance and support.
GE Fanuc Automation
North America, Inc.
gefanuc.com
Circle 339
