Literature Offers
Pallet racks
Advantages of Steel King's SK3000 structural bolted pallet rack are explored in a 12-p brochure. The cost-effective and safe storage rack system is made of hot rolled structural channel steel frame columns, structural angle frame braces, and high strength dual-bolt beam connections.
Steel King Industries, Inc.
Write 316 on PE card
Waterproofing systems
Traffic-bearing waterproofing systems designed to restore and protect concrete parking garages and decks are the main topic of Neogard's Auto-Gard brochure. Auto-Gard features the most advanced developments in polyurethane and epoxy resin technology.
Write 317 on PE card
Fluid power
Clippard Instrument Laboratory, Inc. releases a complete miniature fluid power catalog including technical information and product applications. The 384-p catalog, divided into five main product categories, features color photos and technical drawings for Clippard's line of more than 3500 standard products.
Write 318 on PE card
Wanner Engineering Inc.'s Vector Series Peristaltic Pump brochure focuses on pumps for moving viscous, aggressive, abrasive, and corrosive fluids. Information on pump features, industries and applications served, and available materials of construction are included.
Write 319 on PE card
Comprehensive catalog
Legris, Inc. releases an instructional catalog with nearly 5000 entries, including a full range of pneumatic push-to-connect nylon and nickel plated brass fittings, stainless steel fittings, tubing, flow controls, ball valves, brass compression fittings, and quick disconnect couplers. The catalog provides data on technical characteristics and advantages of each product range, application photos, and conversion tables.
Legris, Inc.
Write 320 on PE card
Air pollution control
A catalog describes applications and operation of Tri-Mer air pollution control systems, including the CCS for submicron particulate. Information on scrubber technology for acids and fumes, as well as for emergency use, are contained in the catalog, which also discusses Tri-Mer thermoplastic tanks, ventilation, and oil mist collectors.
Tri-Mer Corporation
Write 321 on PE card
The Moyno Annihilator, a twin-shaft solids reduction unit for applications such as sewage lift stations, is the focus of a 6-p, full-color bulletin. Features of the Annihilator include counter-rotating hexagonal shaft design and 5-tooth steel cutters providing shredding strength necessary to process from 300 to 4250 GPM of influent.
Moyno, Inc.
Write 322 on PE card
detection A manufacturer of commercial fire alarm systems, NOTIFIER introduces an Advanced Detection brochure containing solutions for environments with complex fire detection needs. The four-color brochure includes application suggestions for the full spectrum of NOTIFIER detection systems.
Write 323 on PE card
