Lined pumps cut costs and lead times
The 3298 Series heavy-duty, magnetically driven, lined ANSI process pumps are available in frame mounted, close-coupled, vertical in-line, and self-priming configurations.
The 3298 Series heavy-duty, magnetically driven, lined ANSI process pumps are available in frame mounted, close-coupled, vertical in-line, and self-priming configurations. Less costly than high alloy alternatives, the liquid end parts are lined with a thick layer of Tefzel (ETFE) for universal corrosion resistance. This material also provides an impenetrable barrier against leakage.
Goulds Pumps, ITT Industries; www.goulds.com
TO VOTE, WRITE 145 ON BALLOT
For more information, circle 407 on card
