Linear position sensor
The Positek E111 linear position sensor is designed for use in potentially explosive dust and gas/vapor atmospheres.
The Positek E111 linear position sensor is designed for use in potentially explosive dust and gas/vapor atmospheres. With no wearing contacts, the sensor is highly linear and repeatable, and it is built and calibrated for measurements ranging from 50 to 600 millimeters. The unit is offered with a variety of mounting configurations and an optional shaft boot for protection against particle ingestion. Its body and 12.7-millimeter target rod are constructed of stainless steel for corrosion resistance.
Everight Position Technologies Corp.
www.everightsensors.com
