Light system for commercial HVAC units
The Stinger UV-C fixture series is designed to efficiently destroy surface microbes and degrade organic materials that impede HVAC system efficiency.
By UV Resources January 27, 2015
The Stinger UV-C fixture series from UV Resources is designed to efficiently destroy surface microbes and degrade organic materials that impede HVAC system efficiency. It mounts from the exterior and requires no interior unit access, which makes the Stinger UV-C fixture ideal for hard-to-access HVAC equipment including fan coils, heat pumps, unit ventilators, terminal units, or individual duct runs. The Stinger is also useful for critical areas including units above ceilings, or in specialty equipment applications in hospitals, industrial plants, and pharmaceutical facilities. Stinger’s components are water resistant and are easily installed in most hard-to-access equipment.
UV Resources
www.uvresources.com
