Light, medium-duty encoders
AutomationDirect's light- and medium-duty encoders are designed for small applications and feature reinforced aluminum die cast casing and have an operating temperature range of -10 to +70 C.
11/19/2012
AutomationDirect's light- and medium-duty encoders are designed for small applications and feature reinforced aluminum die cast casing and have an operating temperature range of -10 to +70 degrees C. Courtesy: AutomationDirectAutomationDirect's Koyo inch-size stainless steel solid-shaft light- and medium-duty encoders are effective for small applications.
The TRDA-2E series light-duty encoders have a 0.25-inch diameter stainless steel solid shaft and offer resolutions from 100 to 2,500 pulses per revolution. The encoders are fitted with a two-meter cable with tinned ends and are available with 12-24 V dc open-collector or 5 V dc line-driver outputs; the series provides up to 200 kHz response frequency.
The TRDA-20 series medium-duty encoders have a 0.375-inch diameter stainless steel solid shaft and offer resolutions from 100 to 2,500 pulses per revolution. The encoders are fitted with a two-meter cable with tinned ends and are available with 5-30 V dc totem-pole (push/pull) or 5 V dc line-driver outputs; the series provides up to 200 kHz response frequency.
The TRDA-25 series medium-duty encoders have a 0.375-in. dia. stainless steel solid shaft and offer resolutions from 100 to 2,500 pulses per revolution. Fitted with a military-style connector, these encoders also have a removable 2.5-inch round flange. Available with 5-30 V dc totem-pole (push/pull) or 5 V dc line-driver outputs, the series provides up to 200 kHz response frequency.
All TRDA encoders feature a reinforced aluminum die cast casing, have an operating temperature range of -10 to +70 C, and have no mounting restrictions. Flexible encoder couplings in aluminum and glass reinforced resin, servo mount brackets, mounting brackets and flanges also are available.
AutomationDirect
www.automationdirect.com
2015 Top Plant: Phoenix Contact, Middletown, Pa.; 2015 Best Practices: Automation, Electrical Safety, Electrical Systems, Pneumatics, Material Handling, Mechanical Systems
A cool solution: Collaboration, chemistry leads to foundry coat product development; See the 2015 Product of the Year Finalists
Raising the standard: What's new with NFPA 70E; A global view of manufacturing; Maintenance data; Fit bearings properly
Special report: U.S. natural gas; LNG transport technologies evolve to meet market demand; Understanding new methane regulations; Predictive maintenance for gas pipeline compressors
Cyber security cost-efficient for industrial control systems; Extracting full value from operational data; Managing cyber security risks
Drilling for Big Data: Managing the flow of information; Big data drilldown series: Challenge and opportunity; OT to IT: Creating a circle of improvement; Industry loses best workers, again
Migrating industrial networks; Tracking HMI advances; Making the right automation changes
Understanding transfer switch operation; Coordinating protective devices; Analyzing NEC 2014 changes; Cooling data centers
Upgrading secondary control systems; Keeping enclosures conditioned; Diagnostics increase equipment uptime; Mechatronics simplifies machine design
After almost a decade of uncertainty, the confidence of plant floor managers is soaring. Even with a number of challenges and while implementing new technologies, there is a renewed sense of optimism among plant managers about their business and their future.
The respondents to the 2014 Plant Engineering Salary Survey come from throughout the U.S. and serve a variety of industries, but they are uniform in their optimism about manufacturing. This year’s survey found 79% consider manufacturing a secure career. That’s up from 75% in 2013 and significantly higher than the 63% figure when Plant Engineering first started asking that question a decade ago.
Read more: 2014 Salary Survey: Confidence rises amid the challenges
This article collection contains several articles on the vital role that compressed air plays in manufacturing plants.
