LED Series Fixtures
The WFH LED luminaire is tested and rated for 60,000 hours of maintenance free use and carries a five-year warranty
April 16, 2013
The WFH LED luminaire offers an LED light source tested and rated for 60,000 hours of maintenance free use and carries a five-year warranty against manufacturer’s defect and lumen output loss. It features a watershed design, heavy duty aluminum construction, FDA accepted baked on finish and is rated for temperatures from -20°F to +50°C (122°F). Available with a 2 X 4 housing, welded aluminum lens frame, captive stainless steel hardware and a watershed design, it offers true industrial performance in the most demanding environments. It is also available with either a clear or a prismatic acrylic lens.
Rig-A-Lite
www.rigalite.com
