LED power supplies
Sunpower's Mean Well HLG-240H-C series are 250W AC/DC LED power supplies that deliver high output currents even at high output voltages.
By Sunpower Technology LLP April 2, 2015
Sunpower’s Mean Well HLG-240H-C series are 250W AC/DC LED power supplies that deliver high output currents even at high output voltages. All models have universal 90-305 VAC inputs, qualifying them for use with 277VAC American industrial mains supplies. Large LED light arrays are supported by different models with constant current outputs from 700mA to 2100mA at corresponding voltages from 59VDC to 357VDC. They are housed in aluminium cases rated to IP65 or IP67 moisture and dust ingress protection, and can withstand vibration to 5G.4kV surge immunity protection is also provided, as well as protection from short circuit, over voltage and over temperature. The units are certified to UL, CSA and ENEC EN safety standards, and have EMC emission and immunity compliance certification.
Sunpower
www.sunpower-uk.com
