LED pedestal mounted work light
The BML-150LED is a 150 watt LED pedestal mount work light that produces 14,790 lumens of light capable of illuminating an area 18,000 square feet in size.
The BML-150LED is is a magnetically mounted LED work light that produces 14,790 lumens of high intensity light and includes an inline AC to DC transformer for easy connection to standard 110-277 volts AC. The mounting pedestal on this LED work light is constructed of aluminum and designed to allow users to place the unit on any flat surface for stable deployment as a pedestal light. The unit is equipped with four 200 pound grip magnetic feet, providing a total of 800 pounds of gripping force, allowing operators to securely mount the unit to metallic surfaces such as tank walls or equipment for use as a temporary work light.
Larson Electronics
www.larsonelectronics.com
