LED flashlights
The 2365 Flex-Neck LED and 2360 LED flashlights are both powered by two double-A batteries.
The 2365 Flex-Neck LED and 2360 LED flashlights are both powered by two double-A batteries. The 2365 Flex-Neck flashlightfeatures a nearly 15-inch flexible cable neck for versatile positioning. Weighing in at 9.3 ounces with batteries, the light comes with a magnetic bracket clip and provides light for nearly 15 hours, with a peak output of 45 lumens. The 2360 LED weighs 4.6 ounces with batteries and provides a peak light output of 100 lumens, with a run time up to 2.5 hours. It also features a multi-position, removable black-oxide coated metal clip. Pelican Products Inc. www.pelican.com
