Laser aligns pulleys
DotLine laser combines V-belt pulley precision alignment with laser leveling in a handheld, permanently calibrated tool. Tight space is no limitation as this lightweight, waterproof tool can be attached magnetically to the outside or inside of a pulley.
DotLine laser combines V-belt pulley precision alignment with laser leveling in a handheld, permanently calibrated tool. Tight space is no limitation as this lightweight, waterproof tool can be attached magnetically to the outside or inside of a pulley. A bright, fanned laser beam is projected onto three magnetic targets placed on the opposite pulley to view alignment. The laser can be switched to a red dot for leveling.
Ludeca, Inc.
www.ludeca.com
Circle 378
