Large capacity oil-free compressor resists corrosion
Sierra 250-400 hp large-capacity, rotary screw air compressor is designed to provide years of troublefree service. The rotor/housing coating resists corrosion, wear, and degradation.
By Staff November 1, 1999
Sierra 250-400 hp large-capacity, rotary screw air compressor is designed to provide years of troublefree service. The rotor/housing coating resists corrosion, wear, and degradation. Critical sealing and compression parts and piping are constructed of stainless steel. Aluminum moisture separators and non-corrosive compression module components provide long life and clean air.
Ingersoll-Rand Co., Rotary Compressor Div.; www.ingersoll-rand. com
TO VOTE, WRITE 94 ON BALLOT
For more information, circle 376 on card
