Lamp and ballast guide
Industrial lighting varies widely by environment and application. Workplaces range from control room to laboratory to warehouse. Each has its own lighting requirements.
12/01/2000
The industrial workplace environment is divided into two general categories-low bay and high bay. Areas where the luminaire is less than 20-ft above the floor are considered low bay, while areas where the luminaire is more than 20-ft above the floor are high bay. Low bay fixtures should spread light and reduce glare, while high bay units should concentrate light with a medium spread and prominent downward light component.
Luminance- also called brightness-is light emitted from a surface. It is measured in candelas per square meter. Luminance levels should be kept uniform to prevent worker eyestrain and fatigue, which could affect productivity. Also, accidents could occur when moving between areas not uniformly illuminated.
Lumen output of a lamp at approximately 100 hr of operation is known as initial lumens. The output of a lamp after it has operated for approximately 40% of its rated life is known as mean lumens.
Color temperature describes the appearance of the lamp source measured in deg Kelvin. High numbers are considered cool and blue in appearance. Low numbers are warm and red/yellow in appearance.
Color rendering index (CRI) measures on a scale of 1-100 how accurately colors appear under a certain source. The most accurate rendering is 100.
Lamp efficacy is measured in lumens per Watt and is the efficiency of the lamp. Like miles per gallon, the higher the number, the better the energy efficiency.
Ballasts
Arc discharge lamps, such as HID and fluorescent, require ballasts to establish the arc and maintain electrical current once the arc is struck. Ballasts also compensate for voltage variations.
Magnetic and electronic ballasts are available for fluorescent lighting systems. Ongoing developments in both lamps and ballasts are improving their efficiencies and extending their lives. Both translate to cost reductions in your plant.
Typical industrial facility areas
  • Production
      • Inspection
          • Warehouses
              • Offices
                  • Public areas
                      • Laboratories
                          • Clean rooms
                              • Control rooms
                                • Critical lighting parameters
                                  • Adequate lighting levels
                                      • Uniform illuminance
                                          • Vertical lighting
                                              • Glare reduction
                                                  • Balance brightness
                                                      • Appropriate color performance
                                                          • Appropriate mounting heights
                                                            • Plant Engineeringmagazine extends its appreciation to Philips Lighting and Lithonia Lighting for the use of their material in the preparation of this article.
                                                              -Jack Smith, Senior Editor, 630-320-7147, jsmith@cahners.com
                                                              &HEADLINE>HID ballast terminology&/HEADLINE>
                                                              Ballast regulation. Ability of a ballast to control lamp wattage, and therefore lamp output, when subjected to changes in line voltage.
                                                              Dip tolerance. Amount of line voltage drop a ballast can sustain before the lamp extinguishes. Usually expressed as a percentage; the higher the percentage, the better.
                                                              Ballast losses. Amount of additional energy a ballast consumes to operate the lamp (line Watts minus lamp Watts). There is usually a tradeoff between ballast losses and ballast regulation.
                                                              Constant wattage autotransformer (CWA). Lead-type regulator and the most widely used HID ballast. It offers good ballast regulation and moderate ballast losses. CWA is available for metal halide and high-pressure sodium lamps.
                                                              SCWA. Pulse-start version of the CWA ballast, but with greater lumen capabilities. Use on pulse-start metal halide lamps only.
                                                              LLRPSL. Low loss reactor used in areas with very little line voltage regulation. They are designed as an energy saving system. Use on pulse-start metal halide lamps only.
                                                              RLB. Regulated lag ballast (LAG-type regulator, "reg-lag") used in areas where line dip tolerance is critical. It exhibits the best ballast regulation. Use on pulse-start metal halide lamps only.
                                                              MRB. Magnetic regulated ballast referred to as a regulated or stabilized type, has operating characteristics similar to the RLB. Use on high-pressure sodium sources only.
                                                              Lighting warehouse areas
                                                              <table ID = 'id2736646-130-table' CELLSPACING = '0' CELLPADDING = '3' BORDER = '1' STYLE = 'background-color: #FFFFFF'><tbody ID = 'id2736656-130-tbody'><tr ID = 'id2736659-130-tr'><td ID = 'id2736661-130-td' VALIGN = 'top' STYLE = 'background-color: #F8F2E6'></td></tr><tr ID = 'id2736668-132-tr'>Open areasFootcandles on floor</tr><tr ID = 'id2736685-137-tr'><td ID = 'id2736687-137-td'>
                                                              Receipt/dispatch </td><td ID = 'id2736696-141-td'></td></tr><tr ID = 'id2736702-144-tr'><td ID = 'id2736704-144-td'>
                                                              Loading bays</td><td ID = 'id2736711-146-td'>
                                                              15</td></tr><tr ID = 'id2736718-149-tr'><td ID = 'id2736720-149-td'>
                                                              Unpacking, sorting,</td></tr><tr ID = 'id2736728-152-tr'><td ID = 'id2736730-152-td'>
                                                              and control station</td><td ID = 'id2736737-154-td'>
                                                              20</td></tr><tr ID = 'id2736744-157-tr'><td ID = 'id2736747-157-td'>
                                                              Packing and dispatch</td><td ID = 'id2736753-159-td'>
                                                              30</td></tr><tr ID = 'id2736761-162-tr'><td ID = 'id2736763-162-td'>
                                                              Supervisor's desk</td><td ID = 'id2736770-164-td'>
                                                              50</td></tr><tr ID = 'id2736777-167-tr'><td ID = 'id2736779-167-td'>
                                                              Open areas </td><td ID = 'id2736788-171-td'></td></tr><tr ID = 'id2736794-174-tr'><td ID = 'id2736796-174-td'>
                                                              Large item storage</td><td ID = 'id2736803-176-td'>
                                                              10</td></tr><tr ID = 'id2736811-179-tr'><td ID = 'id2736813-179-td'>
                                                              Medium item storage</td><td ID = 'id2736820-181-td'>
                                                              20</td></tr><tr ID = 'id2736827-184-tr'><td ID = 'id2736829-184-td'>
                                                              Small item storage</td><td ID = 'id2736836-186-td'>
                                                              30</td></tr><tr ID = 'id2736843-189-tr'><td ID = 'id2736846-189-td'>
                                                              Rack areas </td><td ID = 'id2736854-193-td'>
                                                              Footcandles on racks </td></tr><tr ID = 'id2736864-198-tr'><td ID = 'id2736866-198-td'>
                                                              Manual racks </td><td ID = 'id2736875-202-td'></td></tr><tr ID = 'id2736882-205-tr'><td ID = 'id2736884-205-td'>
                                                              Large item storage</td><td ID = 'id2736890-207-td'>
                                                              10</td></tr><tr ID = 'id2736898-210-tr'><td ID = 'id2736900-210-td'>
                                                              Medium item storage</td><td ID = 'id2736907-212-td'>
                                                              20</td></tr><tr ID = 'id2736914-215-tr'><td ID = 'id2736916-215-td'>
                                                              Small item storage</td><td ID = 'id2736923-217-td'>
                                                              30</td></tr><tr ID = 'id2736930-220-tr'><td ID = 'id2736932-220-td'>
                                                              Self-service racks </td><td ID = 'id2736941-224-td'>
                                                              50</td></tr><tr ID = 'id2736949-227-tr'><td ID = 'id2736951-227-td'>
                                                              Automated racks, high-rise aisles </td><td ID = 'id2736959-231-td'>
                                                              20-50</td></tr></tbody></table>
                                                              Fluorescent lamp data
                                                              <table ID = 'id2736984-241-table' CELLSPACING = '0' CELLPADDING = '3' BORDER = '1' STYLE = 'background-color: #FFFFFF'><tbody ID = 'id2743385-241-tbody'><tr ID = 'id2743387-241-tr'><td ID = 'id2743389-241-td' VALIGN = 'top' STYLE = 'background-color: #F8F2E6'></td></tr><tr ID = 'id2743396-243-tr'>Lamp typeInitial lumensMean lumensLumen depreciationLamp life, 3 hr/startColor rendering index (CRI)Lamp efficacy,1mean lumens/W</tr><tr ID = 'id2743446-258-tr'><td ID = 'id2743448-258-td'>
                                                              F40 T12 Energy saving</td><td ID = 'id2743454-260-td'>
                                                              2650</td><td ID = 'id2743461-262-td'>
                                                              2306</td><td ID = 'id2743468-264-td'>
                                                              0.87</td><td ID = 'id2743474-266-td'>
                                                              20,000</td><td ID = 'id2743481-268-td'>
                                                              60-70</td><td ID = 'id2743488-270-td'>
                                                              65</td></tr><tr ID = 'id2743495-273-tr'><td ID = 'id2743497-273-td'>
                                                              F40 T12 Energy saving high color</td><td ID = 'id2743504-275-td'>
                                                              2800</td><td ID = 'id2743510-277-td'>
                                                              2520</td><td ID = 'id2743517-279-td'>
                                                              0.90</td><td ID = 'id2743524-281-td'>
                                                              20,000</td><td ID = 'id2743530-283-td'>
                                                              70-80</td><td ID = 'id2743537-285-td'>
                                                              71</td></tr><tr ID = 'id2743544-288-tr'><td ID = 'id2743547-288-td'>
                                                              F32 T8</td><td ID = 'id2743553-290-td'>
                                                              2850</td><td ID = 'id2743560-292-td'>
                                                              2565</td><td ID = 'id2743567-294-td'>
                                                              0.90</td><td ID = 'id2743573-296-td'>
                                                              20,000</td><td ID = 'id2743580-298-td'>
                                                              75</td><td ID = 'id2743586-300-td'>
                                                              86</td></tr><tr ID = 'id2743594-303-tr'><td ID = 'id2743596-303-td'>
                                                              F32 T8 High color</td><td ID = 'id2743603-305-td'>
                                                              2950</td><td ID = 'id2743609-307-td'>
                                                              2655</td><td ID = 'id2743616-309-td'>
                                                              0.90</td><td ID = 'id2743623-311-td'>
                                                              20,000</td><td ID = 'id2743629-313-td'>
                                                              82-95</td><td ID = 'id2743636-315-td'>
                                                              89</td></tr><tr ID = 'id2743643-318-tr'><td ID = 'id2743646-318-td'>
                                                              F32 T8 Long life</td><td ID = 'id2743652-320-td'>
                                                              3000</td><td ID = 'id2743659-322-td'>
                                                              2850</td><td ID = 'id2743666-324-td'>
                                                              0.95</td><td ID = 'id2743672-326-td'>
                                                              24,000</td><td ID = 'id2743679-328-td'>
                                                              85</td><td ID = 'id2743685-330-td'>
                                                              95</td></tr><tr ID = 'id2743693-333-tr'><td ID = 'id2743695-333-td'>
                                                              Slimline </td></tr><tr ID = 'id2743705-338-tr'><td ID = 'id2743707-338-td'>
                                                              F48 T12</td><td ID = 'id2743714-340-td'>
                                                              2900</td><td ID = 'id2743720-342-td'>
                                                              2610</td><td ID = 'id2743727-344-td'>
                                                              0.90</td><td ID = 'id2743734-346-td'>
                                                              9000</td><td ID = 'id2743740-348-td'>
                                                              60-70</td><td ID = 'id2743747-350-td'>
                                                              54</td></tr><tr ID = 'id2743755-353-tr'><td ID = 'id2743757-353-td'>
                                                              F48 T12 Energy saving</td><td ID = 'id2743763-355-td'>
                                                              2400</td><td ID = 'id2743770-357-td'>
                                                              2160</td><td ID = 'id2743777-359-td'>
                                                              0.90</td><td ID = 'id2743783-361-td'>
                                                              9000</td><td ID = 'id2743790-363-td'>
                                                              62</td><td ID = 'id2743797-365-td'>
                                                              54</td></tr><tr ID = 'id2743804-368-tr'><td ID = 'id2743806-368-td'>
                                                              F96 T12 Energy saving</td><td ID = 'id2743813-370-td'>
                                                              5500</td><td ID = 'id2743820-372-td'>
                                                              4950</td><td ID = 'id2743826-374-td'>
                                                              0.90</td><td ID = 'id2743833-376-td'>
                                                              12,000</td><td ID = 'id2743840-378-td'>
                                                              60-70</td><td ID = 'id2743846-380-td'>
                                                              79</td></tr><tr ID = 'id2743854-383-tr'><td ID = 'id2743856-383-td'>
                                                              F96 T8</td><td ID = 'id2743863-385-td'>
                                                              5700</td><td ID = 'id2743869-387-td'>
                                                              5244</td><td ID = 'id2743876-389-td'>
                                                              0.92</td><td ID = 'id2743883-391-td'>
                                                              15,000</td><td ID = 'id2743889-393-td'>
                                                              75</td><td ID = 'id2743896-395-td'>
                                                              98</td></tr><tr ID = 'id2743903-398-tr'><td ID = 'id2743905-398-td'>
                                                              F96 T8 High color</td><td ID = 'id2743912-400-td'>
                                                              5900</td><td ID = 'id2743919-402-td'>
                                                              5369</td><td ID = 'id2743925-404-td'>
                                                              0.91</td><td ID = 'id2743932-406-td'>
                                                              15,000</td><td ID = 'id2743939-408-td'>
                                                              82-85</td><td ID = 'id2743945-410-td'>
                                                              100</td></tr><tr ID = 'id2743953-413-tr'><td ID = 'id2743955-413-td'>
                                                              High output </td></tr><tr ID = 'id2743965-418-tr'><td ID = 'id2743967-418-td'>
                                                              F48 T12 HO</td><td ID = 'id2743974-420-td'>
                                                              4050</td><td ID = 'id2743980-422-td'>
                                                              3483</td><td ID = 'id2743987-424-td'>
                                                              0.86</td><td ID = 'id2743994-426-td'>
                                                              12,000</td><td ID = 'id2744000-428-td'>
                                                              60-70</td><td ID = 'id2744007-430-td'>
                                                              51</td></tr><tr ID = 'id2744015-433-tr'><td ID = 'id2744017-433-td'>
                                                              Energy saving</td><td ID = 'id2744023-435-td'>
                                                              8000</td><td ID = 'id2744030-437-td'>
                                                              6960</td><td ID = 'id2744037-439-td'>
                                                              0.87</td><td ID = 'id2744043-441-td'>
                                                              12,000</td><td ID = 'id2744050-443-td'>
                                                              60-70</td><td ID = 'id2744057-445-td'>
                                                              67</td></tr><tr ID = 'id2744064-448-tr'><td ID = 'id2744066-448-td'>
                                                              F96 T8 HO</td><td ID = 'id2744073-450-td'>
                                                              8200</td><td ID = 'id2744080-452-td'>
                                                              7626</td><td ID = 'id2744086-454-td'>
                                                              0.93</td><td ID = 'id2744093-456-td'>
                                                              18,000</td><td ID = 'id2744100-458-td'>
                                                              75</td><td ID = 'id2744106-460-td'>
                                                              95</td></tr></tbody></table>
                                                              1Based on ANSI input watts of a two-lamp ballast; T12 using magnetic ballast and T8 using electronic ballast.
                                                              F numbers refer to wattage, where an F48 lamp is rated at 48 W.
                                                              IESNA recommended lighting levels
                                                              <table ID = 'id2744142-473-table' CELLSPACING = '0' CELLPADDING = '3' BORDER = '1' STYLE = 'background-color: #FFFFFF'><tbody ID = 'id2744152-473-tbody'><tr ID = 'id2744154-473-tr'><td ID = 'id2744156-473-td' VALIGN = 'top' STYLE = 'background-color: #F8F2E6'></td></tr><tr ID = 'id2744164-475-tr'>Indoor activityAverage fc1Average lux</tr><tr ID = 'id2744187-482-tr'><td ID = 'id2744189-482-td'>
                                                              Assembly </td><td ID = 'id2744198-486-td'></td><td ID = 'id2744203-488-td'></td></tr><tr ID = 'id2744210-491-tr'><td ID = 'id2744212-491-td'>
                                                              Simple</td><td ID = 'id2744218-493-td'>
                                                              30</td><td ID = 'id2744225-495-td'>
                                                              300</td></tr><tr ID = 'id2744232-498-tr'><td ID = 'id2744235-498-td'>
                                                              Difficult</td><td ID = 'id2744241-500-td'>
                                                              100</td><td ID = 'id2744248-502-td'>
                                                              1000</td></tr><tr ID = 'id2744255-505-tr'><td ID = 'id2744258-505-td'>
                                                              Exacting</td><td ID = 'id2744264-507-td'>
                                                              300--1000</td><td ID = 'id2744271-509-td'>
                                                              3000-10,000</td></tr><tr ID = 'id2744279-512-tr'><td ID = 'id2744281-512-td'>
                                                              Raw material processing (cleaning, cutting, crushing, sorting, grading, etc.) </td></tr><tr ID = 'id2744291-517-tr'><td ID = 'id2744293-517-td'>
                                                              Course</td><td ID = 'id2744300-519-td'>
                                                              10</td><td ID = 'id2744306-521-td'>
                                                              100</td></tr><tr ID = 'id2744314-524-tr'><td ID = 'id2744316-524-td'>
                                                              Medium</td><td ID = 'id2744323-526-td'>
                                                              30</td><td ID = 'id2744329-528-td'>
                                                              300</td></tr><tr ID = 'id2744336-531-tr'><td ID = 'id2744339-531-td'>
                                                              Fine</td><td ID = 'id2744345-533-td'>
                                                              50</td><td ID = 'id2744352-535-td'>
                                                              500</td></tr><tr ID = 'id2744359-538-tr'><td ID = 'id2744362-538-td'>
                                                              Very fine</td><td ID = 'id2744368-540-td'>
                                                              100</td><td ID = 'id2744375-542-td'>
                                                              1000</td></tr><tr ID = 'id2744382-545-tr'><td ID = 'id2744384-545-td'>
                                                              Inspection </td></tr><tr ID = 'id2744394-550-tr'><td ID = 'id2744396-550-td'>
                                                              Simple</td><td ID = 'id2744403-552-td'>
                                                              30</td><td ID = 'id2744410-554-td'>
                                                              300</td></tr><tr ID = 'id2744417-557-tr'><td ID = 'id2744419-557-td'>
                                                              Difficult</td><td ID = 'id2744426-559-td'>
                                                              100</td><td ID = 'id2744432-561-td'>
                                                              1000</td></tr><tr ID = 'id2744440-564-tr'><td ID = 'id2744442-564-td'>
                                                              Exacting</td><td ID = 'id2744449-566-td'>
                                                              300-1000</td><td ID = 'id2744455-568-td'>
                                                              3000-10,000</td></tr><tr ID = 'id2744463-571-tr'><td ID = 'id2744465-571-td'>
                                                              Material handling </td></tr><tr ID = 'id2744475-576-tr'><td ID = 'id2744477-576-td'>
                                                              Shipping and receiving</td><td ID = 'id2744484-578-td'>
                                                              30</td><td ID = 'id2744490-580-td'>
                                                              300</td></tr><tr ID = 'id2744498-583-tr'><td ID = 'id2744500-583-td'>
                                                              Wrapping, packing, labeling</td><td ID = 'id2744506-585-td'>
                                                              30</td><td ID = 'id2744513-587-td'>
                                                              300</td></tr><tr ID = 'id2744520-590-tr'><td ID = 'id2744522-590-td'>
                                                              Picking stock and classifying</td><td ID = 'id2744529-592-td'>
                                                              30</td><td ID = 'id2744535-594-td'>
                                                              300</td></tr><tr ID = 'id2744543-597-tr'><td ID = 'id2744545-597-td'>
                                                              Loading (inside truck)</td><td ID = 'id2744551-599-td'>
                                                              10</td><td ID = 'id2744558-601-td'>
                                                              100</td></tr><tr ID = 'id2744565-604-tr'><td ID = 'id2739170-604-td'>
                                                              Machining </td></tr><tr ID = 'id2739180-609-tr'><td ID = 'id2739182-609-td'>
                                                              Rough bench or machine work</td><td ID = 'id2739188-611-td'>
                                                              30</td><td ID = 'id2739194-613-td'>
                                                              300</td></tr><tr ID = 'id2739202-616-tr'><td ID = 'id2739204-616-td'>
                                                              Medium bench or machine work</td><td ID = 'id2739210-618-td'>
                                                              50</td><td ID = 'id2739217-620-td'>
                                                              500</td></tr><tr ID = 'id2739224-623-tr'><td ID = 'id2739226-623-td'>
                                                              Fine bench or machine work</td><td ID = 'id2739233-625-td'>
                                                              300-1000</td><td ID = 'id2739240-627-td'>
                                                              3000-10,000</td></tr><tr ID = 'id2739247-630-tr'><td ID = 'id2739249-630-td'>
                                                              Extra-fine bench or machine work</td><td ID = 'id2739256-632-td'>
                                                              300-1000</td><td ID = 'id2739262-634-td'>
                                                              3000-10,000</td></tr><tr ID = 'id2739270-637-tr'><td ID = 'id2739272-637-td'>
                                                              Storage rooms or warehouses </td></tr><tr ID = 'id2739282-642-tr'><td ID = 'id2739284-642-td'>
                                                              Inactive</td><td ID = 'id2739291-644-td'>
                                                              5</td><td ID = 'id2739297-646-td'>
                                                              50</td></tr><tr ID = 'id2739305-649-tr'><td ID = 'id2739307-649-td'>
                                                              Active, bulky items, large labels</td><td ID = 'id2739313-651-td'>
                                                              10</td><td ID = 'id2739320-653-td'>
                                                              100</td></tr><tr ID = 'id2739327-656-tr'><td ID = 'id2739329-656-td'>
                                                              Active, small items, small labels</td><td ID = 'id2739336-658-td'>
                                                              30</td><td ID = 'id2739342-660-td'>
                                                              300</td></tr><tr ID = 'id2739350-663-tr'><td ID = 'id2739352-663-td'>
                                                              Cleanrooms </td></tr><tr ID = 'id2739362-668-tr'><td ID = 'id2739364-668-td'>
                                                              Workspace</td><td ID = 'id2739370-670-td'>
                                                              80</td><td ID = 'id2739377-672-td'>
                                                              800</td></tr><tr ID = 'id2739385-675-tr'><td ID = 'id2739387-675-td'>
                                                              Food processing </td></tr><tr ID = 'id2739397-680-tr'><td ID = 'id2739399-680-td'>
                                                              Workroom</td><td ID = 'id2739406-682-td'>
                                                              30</td><td ID = 'id2739412-684-td'>
                                                              300</td></tr><tr ID = 'id2739420-687-tr'><td ID = 'id2739422-687-td'>
                                                              Inspection areas</td><td ID = 'id2739429-689-td'>
                                                              150</td><td ID = 'id2739436-691-td'>
                                                              1500</td></tr><tr ID = 'id2739443-694-tr'><td ID = 'id2739445-694-td'>
                                                              Outdoor activity</td><td ID = 'id2739452-696-td'>
                                                              Average fc, horizontal/vertical</td><td ID = 'id2739458-698-td'>
                                                              Average lux, horizontal/vertical</td></tr><tr ID = 'id2739466-701-tr'><td ID = 'id2739468-701-td'>
                                                              Building exteriors </td></tr><tr ID = 'id2739478-706-tr'><td ID = 'id2739480-706-td'>
                                                              Active entrances</td><td ID = 'id2739487-708-td'>
                                                              5/3</td><td ID = 'id2739493-710-td'>
                                                              50/30</td></tr><tr ID = 'id2739501-713-tr'><td ID = 'id2739503-713-td'>
                                                              Inactive entrances (normally locked)</td><td ID = 'id2739510-715-td'>
                                                              3/3</td><td ID = 'id2739516-717-td'>
                                                              30/30</td></tr><tr ID = 'id2739524-720-tr'><td ID = 'id2739526-720-td'>
                                                              Building surrounds</td><td ID = 'id2739533-722-td'>
                                                              5/3</td><td ID = 'id2739539-724-td'>
                                                              50/30</td></tr><tr ID = 'id2739547-727-tr'><td ID = 'id2739549-727-td'>
                                                              Storage yards </td></tr><tr ID = 'id2739559-732-tr'><td ID = 'id2739561-732-td'>
                                                              Active</td><td ID = 'id2739568-734-td'>
                                                              10/3</td><td ID = 'id2739574-736-td'>
                                                              100/30</td></tr><tr ID = 'id2739582-739-tr'><td ID = 'id2739584-739-td'>
                                                              Inactive</td><td ID = 'id2739591-741-td'>
                                                              1/0.3</td><td ID = 'id2739597-743-td'>
                                                              10/3</td></tr><tr ID = 'id2739605-746-tr'><td ID = 'id2739607-746-td'>
                                                              Building and monuments, floodlighting (vertical only)</td></tr><tr ID = 'id2739618-751-tr'><td ID = 'id2739620-751-td'>
                                                              Bright surroundings, light surface</td><td ID = 'id2739627-753-td'>
                                                              3</td><td ID = 'id2739633-755-td'>
                                                              30</td></tr><tr ID = 'id2739641-758-tr'><td ID = 'id2739643-758-td'>
                                                              Bright surroundings, dark surface</td><td ID = 'id2739649-760-td'>
                                                              0</td><td ID = 'id2739656-762-td'>
                                                              100</td></tr><tr ID = 'id2739663-765-tr'><td ID = 'id2739665-765-td'>
                                                              Dark surroundings, light surface</td><td ID = 'id2739672-767-td'>
                                                              3</td><td ID = 'id2739678-769-td'>
                                                              30</td></tr><tr ID = 'id2739685-772-tr'><td ID = 'id2739688-772-td'>
                                                              Dark surroundings, dark surface</td><td ID = 'id2739694-774-td'>
                                                              3</td><td ID = 'id2739700-776-td'>
                                                              30</td></tr><tr ID = 'id2739708-779-tr'><td ID = 'id2739710-779-td'>
                                                              1Task may be horizontal, inclined, or vertical</td></tr></tbody></table>
                                                              HID lamp data
                                                              <table ID = 'id2739734-789-table' CELLSPACING = '0' CELLPADDING = '3' BORDER = '1' STYLE = 'background-color: #FFFFFF'><tbody ID = 'id2739745-789-tbody'><tr ID = 'id2739747-789-tr'><td ID = 'id2739749-789-td' VALIGN = 'top' STYLE = 'background-color: #F8F2E6'></td></tr><tr ID = 'id2739756-791-tr'>Nominal lamp wattageInitial lumensMean lumensLamp life, 10 hr/startColor rendering index (CRI)Typical startup, minTypical restrike, minLamp efficiency, means lumens/W</tr><tr ID = 'id2739812-808-tr'><td ID = 'id2739814-808-td'>
                                                              Metal halide - clear </td></tr><tr ID = 'id2739824-813-tr'><td ID = 'id2739826-813-td'>
                                                              175</td><td ID = 'id2739833-815-td'>
                                                              14,000</td><td ID = 'id2739840-817-td'>
                                                              12,000</td><td ID = 'id2739846-819-td'>
                                                              10,000</td><td ID = 'id2739853-821-td'>
                                                              65</td><td ID = 'id2739859-823-td'>
                                                              2-5</td><td ID = 'id2739866-825-td'>
                                                              10-15</td><td ID = 'id2739872-827-td'>
                                                              69</td></tr><tr ID = 'id2739880-830-tr'><td ID = 'id2739882-830-td'>
                                                              250</td><td ID = 'id2739888-832-td'>
                                                              22,000</td><td ID = 'id2739895-834-td'>
                                                              17,000</td><td ID = 'id2739902-836-td'>
                                                              10,000</td><td ID = 'id2739908-838-td'>
                                                              65</td><td ID = 'id2739915-840-td'>
                                                              2-5</td><td ID = 'id2739921-842-td'>
                                                              10-15</td><td ID = 'id2739928-844-td'>
                                                              68</td></tr><tr ID = 'id2739936-847-tr'><td ID = 'id2739938-847-td'>
                                                              400</td><td ID = 'id2739944-849-td'>
                                                              36,000</td><td ID = 'id2739951-851-td'>
                                                              25,000</td><td ID = 'id2739958-853-td'>
                                                              20,000</td><td ID = 'id2739964-855-td'>
                                                              65</td><td ID = 'id2739971-857-td'>
                                                              2-5</td><td ID = 'id2739977-859-td'>
                                                              10-15</td><td ID = 'id2739984-861-td'>
                                                              63</td></tr><tr ID = 'id2739991-864-tr'><td ID = 'id2739993-864-td'>
                                                              1000</td><td ID = 'id2740000-866-td'>
                                                              110,000</td><td ID = 'id2740007-868-td'>
                                                              88,000</td><td ID = 'id2740013-870-td'>
                                                              12,000</td><td ID = 'id2740020-872-td'>
                                                              65</td><td ID = 'id2740026-874-td'>
                                                              2-5</td><td ID = 'id2740033-876-td'>
                                                              10-15</td><td ID = 'id2740040-878-td'>
                                                              88</td></tr><tr ID = 'id2740047-881-tr'><td ID = 'id2740049-881-td'>
                                                              Metal halide - coated </td></tr><tr ID = 'id2740059-886-tr'><td ID = 'id2740061-886-td'>
                                                              175</td><td ID = 'id2740068-888-td'>
                                                              14,000</td><td ID = 'id2740074-890-td'>
                                                              10,000</td><td ID = 'id2740081-892-td'>
                                                              10,000</td><td ID = 'id2740088-894-td'>
                                                              70</td><td ID = 'id2740094-896-td'>
                                                              2-5</td><td ID = 'id2740101-898-td'>
                                                              10-15</td><td ID = 'id2740107-900-td'>
                                                              57</td></tr><tr ID = 'id2740115-903-tr'><td ID = 'id2740117-903-td'>
                                                              250</td><td ID = 'id2740123-905-td'>
                                                              21,500</td><td ID = 'id2740130-907-td'>
                                                              17,000</td><td ID = 'id2740137-909-td'>
                                                              10,000</td><td ID = 'id2740143-911-td'>
                                                              70</td><td ID = 'id2740150-913-td'>
                                                              2-5</td><td ID = 'id2740156-915-td'>
                                                              10-15</td><td ID = 'id2740163-917-td'>
                                                              68</td></tr><tr ID = 'id2740170-920-tr'><td ID = 'id2740172-920-td'>
                                                              400</td><td ID = 'id2740179-922-td'>
                                                              36,000</td><td ID = 'id2740185-924-td'>
                                                              25,000</td><td ID = 'id2740192-926-td'>
                                                              20,000</td><td ID = 'id2740199-928-td'>
                                                              70</td><td ID = 'id2740205-930-td'>
                                                              2-5</td><td ID = 'id2740212-932-td'>
                                                              10-15</td><td ID = 'id2740218-934-td'>
                                                              63</td></tr><tr ID = 'id2740226-937-tr'><td ID = 'id2740228-937-td'>
                                                              1000</td><td ID = 'id2740234-939-td'>
                                                              107,000</td><td ID = 'id2740241-941-td'>
                                                              85,000</td><td ID = 'id2740248-943-td'>
                                                              12,000</td><td ID = 'id2740254-945-td'>
                                                              70</td><td ID = 'id2740261-947-td'>
                                                              2-5</td><td ID = 'id2740267-949-td'>
                                                              10-15</td><td ID = 'id2740274-951-td'>
                                                              85</td></tr><tr ID = 'id2740281-954-tr'><td ID = 'id2740284-954-td'>
                                                              Metal halide high output - clear </td></tr><tr ID = 'id2740293-959-tr'><td ID = 'id2740295-959-td'>
                                                              400</td><td ID = 'id2740302-961-td'>
                                                              44,000</td><td ID = 'id2740308-963-td'>
                                                              34,000</td><td ID = 'id2740315-965-td'>
                                                              20,000</td><td ID = 'id2740322-967-td'>
                                                              65</td><td ID = 'id2740328-969-td'>
                                                              2-5</td><td ID = 'id2740334-971-td'>
                                                              10-15</td><td ID = 'id2740341-973-td'>
                                                              85</td></tr><tr ID = 'id2740349-976-tr'><td ID = 'id2740351-976-td'>
                                                              Pulse start metal halide1- clear (requires special ballast and ignitor)</td></tr><tr ID = 'id2740361-981-tr'><td ID = 'id2740364-981-td'>
                                                              70</td><td ID = 'id2740370-983-td'>
                                                              5500</td><td ID = 'id2740377-985-td'>
                                                              4070</td><td ID = 'id2740383-987-td'>
                                                              12,000</td><td ID = 'id2740390-989-td'>
                                                              65</td><td ID = 'id2740396-991-td'>
                                                              2</td><td ID = 'id2740403-993-td'>
                                                              3-4</td><td ID = 'id2740409-995-td'>
                                                              58</td></tr><tr ID = 'id2740417-998-tr'><td ID = 'id2740419-998-td'>
                                                              100</td><td ID = 'id2740426-1000-td'>
                                                              9000</td><td ID = 'id2740432-1002-td'>
                                                              6390</td><td ID = 'id2740439-1004-td'>
                                                              15,000</td><td ID = 'id2740446-1006-td'>
                                                              65</td><td ID = 'id2740452-1008-td'>
                                                              2</td><td ID = 'id2740458-1010-td'>
                                                              3-4</td><td ID = 'id2740465-1012-td'>
                                                              64</td></tr><tr ID = 'id2740473-1015-tr'><td ID = 'id2740475-1015-td'>
                                                              150</td><td ID = 'id2740481-1017-td'>
                                                              15,000</td><td ID = 'id2740488-1019-td'>
                                                              11,300</td><td ID = 'id2740494-1021-td'>
                                                              15,000</td><td ID = 'id2740501-1023-td'>
                                                              65</td><td ID = 'id2740508-1025-td'>
                                                              2</td><td ID = 'id2740514-1027-td'>
                                                              3-4</td><td ID = 'id2740520-1029-td'>
                                                              75</td></tr><tr ID = 'id2740528-1032-tr'><td ID = 'id2740530-1032-td'>
                                                              200</td><td ID = 'id2740537-1034-td'>
                                                              21,000</td><td ID = 'id2740543-1036-td'>
                                                              15,800</td><td ID = 'id2740550-1038-td'>
                                                              15,000</td><td ID = 'id2740557-1040-td'>
                                                              65</td><td ID = 'id2740563-1042-td'>
                                                              2</td><td ID = 'id2740569-1044-td'>
                                                              3-4</td><td ID = 'id2740576-1046-td'>
                                                              79</td></tr><tr ID = 'id2740583-1049-tr'><td ID = 'id2740585-1049-td'>
                                                              320</td><td ID = 'id2740592-1051-td'>
                                                              32,000</td><td ID = 'id2740599-1053-td'>
                                                              21,200</td><td ID = 'id2740605-1055-td'>
                                                              20,000</td><td ID = 'id2740612-1057-td'>
                                                              65</td><td ID = 'id2740618-1059-td'>
                                                              2</td><td ID = 'id2740625-1061-td'>
                                                              3-4</td><td ID = 'id2740631-1063-td'>
                                                              66</td></tr><tr ID = 'id2740639-1066-tr'><td ID = 'id2740641-1066-td'>
                                                              350</td><td ID = 'id2740647-1068-td'>
                                                              36,000</td><td ID = 'id2740654-1070-td'>
                                                              27,000</td><td ID = 'id2740661-1072-td'>
                                                              20,000</td><td ID = 'id2740667-1074-td'>
                                                              65</td><td ID = 'id2740674-1076-td'>
                                                              2</td><td ID = 'id2740680-1078-td'>
                                                              3-4</td><td ID = 'id2740686-1080-td'>
                                                              77</td></tr><tr ID = 'id2740694-1083-tr'><td ID = 'id2740696-1083-td'>
                                                              400</td><td ID = 'id2740702-1085-td'>
                                                              44,000</td><td ID = 'id2740709-1087-td'>
                                                              37,400</td><td ID = 'id2740716-1089-td'>
                                                              30,000</td><td ID = 'id2740722-1091-td'>
                                                              65</td><td ID = 'id2740729-1093-td'>
                                                              2</td><td ID = 'id2740735-1095-td'>
                                                              3-4</td><td ID = 'id2740742-1097-td'>
                                                              94</td></tr><tr ID = 'id2740749-1100-tr'><td ID = 'id2740752-1100-td'>
                                                              Pulse start metal halide1- coated (requires special ballast and ignitor)</td></tr><tr ID = 'id2740762-1105-tr'><td ID = 'id2740764-1105-td'>
                                                              150</td><td ID = 'id2740771-1107-td'>
                                                              14,250</td><td ID = 'id2740777-1109-td'>
                                                              10,300</td><td ID = 'id2740784-1111-td'>
                                                              15,000</td><td ID = 'id2740791-1113-td'>
                                                              70</td><td ID = 'id2740797-1115-td'>
                                                              2</td><td ID = 'id2740804-1117-td'>
                                                              3-4</td><td ID = 'id2740810-1119-td'>
                                                              69</td></tr><tr ID = 'id2740817-1122-tr'><td ID = 'id2740820-1122-td'>
                                                              200</td><td ID = 'id2740826-1124-td'>
                                                              20,000</td><td ID = 'id2740833-1126-td'>
                                                              14,400</td><td ID = 'id2740839-1128-td'>
                                                              15,000</td><td ID = 'id2740846-1130-td'>
                                                              70</td><td ID = 'id2740852-1132-td'>
                                                              2</td><td ID = 'id2740859-1134-td'>
                                                              3-4</td><td ID = 'id2740865-1136-td'>
                                                              72</td></tr><tr ID = 'id2740873-1139-tr'><td ID = 'id2740875-1139-td'>
                                                              350</td><td ID = 'id2740881-1141-td'>
                                                              34,500</td><td ID = 'id2740888-1143-td'>
                                                              24,900</td><td ID = 'id2740894-1145-td'>
                                                              20,000</td><td ID = 'id2740901-1147-td'>
                                                              70</td><td ID = 'id2740908-1149-td'>
                                                              2</td><td ID = 'id2740914-1151-td'>
                                                              3-4</td><td ID = 'id2740920-1153-td'>
                                                              71</td></tr><tr ID = 'id2740928-1156-tr'><td ID = 'id2740930-1156-td'>
                                                              400</td><td ID = 'id2740936-1158-td'>
                                                              42,000</td><td ID = 'id2740943-1160-td'>
                                                              35,200</td><td ID = 'id2740950-1162-td'>
                                                              30,000</td><td ID = 'id2740956-1164-td'>
                                                              70</td><td ID = 'id2740963-1166-td'>
                                                              2</td><td ID = 'id2740969-1168-td'>
                                                              3-4</td><td ID = 'id2740976-1170-td'>
                                                              88</td></tr><tr ID = 'id2740983-1173-tr'><td ID = 'id2740985-1173-td'>
                                                              Pulse start metal halide reg-lag1- clear (requires special reg-lag ballast and ignitor)</td></tr><tr ID = 'id2740997-1178-tr'><td ID = 'id2740999-1178-td'>
                                                              250</td><td ID = 'id2741005-1180-td'>
                                                              23,750</td><td ID = 'id2741012-1182-td'>
                                                              19,000</td><td ID = 'id2741019-1184-td'>
                                                              20,000</td><td ID = 'id2741025-1186-td'>
                                                              65</td><td ID = 'id2741032-1188-td'>
                                                              2</td><td ID = 'id2741038-1190-td'>
                                                              3-4</td><td ID = 'id2741045-1192-td'>
                                                              76</td></tr><tr ID = 'id2741052-1195-tr'><td ID = 'id2741054-1195-td'>
                                                              400</td><td ID = 'id2741061-1197-td'>
                                                              44,000</td><td ID = 'id2741067-1199-td'>
                                                              37,400</td><td ID = 'id2741074-1201-td'>
                                                              30,000</td><td ID = 'id2741081-1203-td'>
                                                              65</td><td ID = 'id2741087-1205-td'>
                                                              2</td><td ID = 'id2741093-1207-td'>
                                                              3-4</td><td ID = 'id2741100-1209-td'>
                                                              94</td></tr><tr ID = 'id2741107-1212-tr'><td ID = 'id2741109-1212-td'>
                                                              Pulse start metal halide reg-lag1- coated (requires special reg-lag ballast and ignitor)</td></tr><tr ID = 'id2741121-1217-tr'><td ID = 'id2741123-1217-td'>
                                                              250</td><td ID = 'id2741130-1219-td'>
                                                              22,600</td><td ID = 'id2741136-1221-td'>
                                                              17,500</td><td ID = 'id2741143-1223-td'>
                                                              20,000</td><td ID = 'id2741150-1225-td'>
                                                              70</td><td ID = 'id2741156-1227-td'>
                                                              2</td><td ID = 'id2741162-1229-td'>
                                                              3-4</td><td ID = 'id2741169-1231-td'>
                                                              70</td></tr><tr ID = 'id2741176-1234-tr'><td ID = 'id2741178-1234-td'>
                                                              400</td><td ID = 'id2741185-1236-td'>
                                                              42,000</td><td ID = 'id2748938-1238-td'>
                                                              35,200</td><td ID = 'id2748945-1240-td'>
                                                              30,000</td><td ID = 'id2748952-1242-td'>
                                                              70</td><td ID = 'id2748958-1244-td'>
                                                              2</td><td ID = 'id2748964-1246-td'>
                                                              3-4</td><td ID = 'id2748971-1248-td'>
                                                              88</td></tr><tr ID = 'id2748978-1251-tr'><td ID = 'id2748980-1251-td'>
                                                              High pressure sodium - clear </td></tr><tr ID = 'id2748990-1256-tr'><td ID = 'id2748992-1256-td'>
                                                              70</td><td ID = 'id2748998-1258-td'>
                                                              6400</td><td ID = 'id2749005-1260-td'>
                                                              5440</td><td ID = 'id2749012-1262-td'>
                                                              24,000</td><td ID = 'id2749018-1264-td'>
                                                              20-25</td><td ID = 'id2749025-1266-td'>
                                                              3-4</td><td ID = 'id2749032-1268-td'>
                                                              1-2</td><td ID = 'id2749038-1270-td'>
                                                              78</td></tr><tr ID = 'id2749045-1273-tr'><td ID = 'id2749048-1273-td'>
                                                              100</td><td ID = 'id2749054-1275-td'>
                                                              9500</td><td ID = 'id2749061-1277-td'>
                                                              8550</td><td ID = 'id2749067-1279-td'>
                                                              24,000</td><td ID = 'id2749074-1281-td'>
                                                              20-25</td><td ID = 'id2749081-1283-td'>
                                                              3-4</td><td ID = 'id2749087-1285-td'>
                                                              1-2</td><td ID = 'id2749093-1287-td'>
                                                              86</td></tr><tr ID = 'id2749101-1290-tr'><td ID = 'id2749103-1290-td'>
                                                              150</td><td ID = 'id2749109-1292-td'>
                                                              16,000</td><td ID = 'id2749116-1294-td'>
                                                              14,400</td><td ID = 'id2749123-1296-td'>
                                                              24,000</td><td ID = 'id2749129-1298-td'>
                                                              20-25</td><td ID = 'id2749136-1300-td'>
                                                              3-4</td><td ID = 'id2749142-1302-td'>
                                                              1-2</td><td ID = 'id2749149-1304-td'>
                                                              96</td></tr><tr ID = 'id2749156-1307-tr'><td ID = 'id2749158-1307-td'>
                                                              200</td><td ID = 'id2749165-1309-td'>
                                                              22,000</td><td ID = 'id2749172-1311-td'>
                                                              19,600</td><td ID = 'id2749178-1313-td'>
                                                              24,000</td><td ID = 'id2749185-1315-td'>
                                                              20-25</td><td ID = 'id2749192-1317-td'>
                                                              3-4</td><td ID = 'id2749198-1319-td'>
                                                              1-2</td><td ID = 'id2749204-1321-td'>
                                                              98</td></tr><tr ID = 'id2749212-1324-tr'><td ID = 'id2749214-1324-td'>
                                                              250</td><td ID = 'id2749220-1326-td'>
                                                              28,000</td><td ID = 'id2749227-1328-td'>
                                                              25,200</td><td ID = 'id2749234-1330-td'>
                                                              24,000</td><td ID = 'id2749240-1332-td'>
                                                              20-25</td><td ID = 'id2749247-1334-td'>
                                                              3-4</td><td ID = 'id2749253-1336-td'>
                                                              1-2</td><td ID = 'id2749260-1338-td'>
                                                              101</td></tr><tr ID = 'id2749267-1341-tr'><td ID = 'id2749269-1341-td'>
                                                              310</td><td ID = 'id2749276-1343-td'>
                                                              37,000</td><td ID = 'id2749283-1345-td'>
                                                              33,300</td><td ID = 'id2749289-1347-td'>
                                                              24,000</td><td ID = 'id2749296-1349-td'>
                                                              20-25</td><td ID = 'id2749303-1351-td'>
                                                              3-4</td><td ID = 'id2749309-1353-td'>
                                                              1-2</td><td ID = 'id2749316-1355-td'>
                                                              107</td></tr><tr ID = 'id2749323-1358-tr'><td ID = 'id2749325-1358-td'>
                                                              350</td><td ID = 'id2749332-1360-td'>
                                                              46,500</td><td ID = 'id2749338-1362-td'>
                                                              44,000</td><td ID = 'id2749345-1364-td'>
                                                              24,000</td><td ID = 'id2749352-1366-td'>
                                                              20-25</td><td ID = 'id2749358-1368-td'>
                                                              3-4</td><td ID = 'id2749365-1370-td'>
                                                              1-2</td><td ID = 'id2749371-1372-td'>
                                                              126</td></tr><tr ID = 'id2749378-1375-tr'><td ID = 'id2749381-1375-td'>
                                                              400</td><td ID = 'id2749387-1377-td'>
                                                              50,000</td><td ID = 'id2749394-1379-td'>
                                                              45,000</td><td ID = 'id2749400-1381-td'>
                                                              24,000</td><td ID = 'id2749407-1383-td'>
                                                              20-25</td><td ID = 'id2749414-1385-td'>
                                                              3-4</td><td ID = 'id2749420-1387-td'>
                                                              1-2</td><td ID = 'id2749426-1389-td'>
                                                              113</td></tr><tr ID = 'id2749434-1392-tr'><td ID = 'id2749436-1392-td'>
                                                              1000</td><td ID = 'id2749443-1394-td'>
                                                              140,000</td><td ID = 'id2749449-1396-td'>
                                                              126,000</td><td ID = 'id2749456-1398-td'>
                                                              24,000</td><td ID = 'id2749463-1400-td'>
                                                              20-25</td><td ID = 'id2749469-1402-td'>
                                                              3-4</td><td ID = 'id2749476-1404-td'>
                                                              1-2</td><td ID = 'id2749482-1406-td'>
                                                              126</td></tr><tr ID = 'id2749490-1409-tr'><td ID = 'id2749492-1409-td'>
                                                              High pressure sodium - coated </td></tr><tr ID = 'id2749501-1414-tr'><td ID = 'id2749504-1414-td'>
                                                              70</td><td ID = 'id2749510-1416-td'>
                                                              5950</td><td ID = 'id2749517-1418-td'>
                                                              5058</td><td ID = 'id2749523-1420-td'>
                                                              24,000</td><td ID = 'id2749530-1422-td'>
                                                              20-25</td><td ID = 'id2749537-1424-td'>
                                                              3-4</td><td ID = 'id2749543-1426-td'>
                                                              1-2</td><td ID = 'id2749549-1428-td'>
                                                              72</td></tr><tr ID = 'id2749557-1431-tr'><td ID = 'id2749559-1431-td'>
                                                              100</td><td ID = 'id2749565-1433-td'>
                                                              8800</td><td ID = 'id2749572-1435-td'>
                                                              7920</td><td ID = 'id2749579-1437-td'>
                                                              24,000</td><td ID = 'id2749585-1439-td'>
                                                              20-25</td><td ID = 'id2749592-1441-td'>
                                                              3-4</td><td ID = 'id2749598-1443-td'>
                                                              1-2</td><td ID = 'id2749605-1445-td'>
                                                              79</td></tr><tr ID = 'id2749612-1448-tr'><td ID = 'id2749614-1448-td'>
                                                              150</td><td ID = 'id2749621-1450-td'>
                                                              15,000</td><td ID = 'id2749628-1452-td'>
                                                              13,500</td><td ID = 'id2749634-1454-td'>
                                                              24,000</td><td ID = 'id2749641-1456-td'>
                                                              20-25</td><td ID = 'id2749648-1458-td'>
                                                              3-4</td><td ID = 'id2749654-1460-td'>
                                                              1-2</td><td ID = 'id2749660-1462-td'>
                                                              90</td></tr><tr ID = 'id2749668-1465-tr'><td ID = 'id2749670-1465-td'>
                                                              250</td><td ID = 'id2749677-1467-td'>
                                                              26,000</td><td ID = 'id2749683-1469-td'>
                                                              23,400</td><td ID = 'id2749690-1471-td'>
                                                              24,000</td><td ID = 'id2749697-1473-td'>
                                                              20-25</td><td ID = 'id2749703-1475-td'>
                                                              3-4</td><td ID = 'id2749710-1477-td'>
                                                              1-2</td><td ID = 'id2749716-1479-td'>
                                                              94</td></tr><tr ID = 'id2749724-1482-tr'><td ID = 'id2749726-1482-td'>
                                                              400</td><td ID = 'id2749732-1484-td'>
                                                              47,500</td><td ID = 'id2749739-1486-td'>
                                                              42,750</td><td ID = 'id2749745-1488-td'>
                                                              24,000</td><td ID = 'id2749752-1490-td'>
                                                              20-25</td><td ID = 'id2749759-1492-td'>
                                                              3-4</td><td ID = 'id2749765-1494-td'>
                                                              1-2</td><td ID = 'id2749772-1496-td'>
                                                              107</td></tr></tbody></table>
                                                              1High lumen, pulse start lamp/ballast system with a capacitor and internal ignitor
                                                              Ballast information for HID
                                                              <table ID = 'id2749803-1508-table' CELLSPACING = '0' CELLPADDING = '3' BORDER = '1' STYLE = 'background-color: #FFFFFF'><tbody ID = 'id2749813-1508-tbody'><tr ID = 'id2749815-1508-tr'><td ID = 'id2749817-1508-td' VALIGN = 'top' STYLE = 'background-color: #F8F2E6'></td></tr><tr ID = 'id2749825-1510-tr'>Ballast typeInput WBallast regulation line voltage/line wattageBallast lossesAverage dip tolerance, %Voltages1</tr><tr ID = 'id2749867-1523-tr'><td ID = 'id2749869-1523-td'>
                                                              Metal halide </td></tr><tr ID = 'id2749879-1528-tr'><td ID = 'id2749881-1528-td'>
                                                              400 W CWA</td><td ID = 'id2749888-1530-td'>
                                                              458</td><td ID = 'id2749894-1532-td'>
                                                              </td><td ID = 'id2749901-1534-td'>
                                                              Medium</td><td ID = 'id2749908-1536-td'>
                                                              50</td><td ID = 'id2749914-1538-td'>
                                                              120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id2749921-1541-tr'><td ID = 'id2749924-1541-td'></td><td ID = 'id2749929-1543-td'></td><td ID = 'id2749934-1545-td'></td><td ID = 'id2749940-1547-td'></td><td ID = 'id2749945-1549-td'></td><td ID = 'id2749950-1551-td'></td></tr><tr ID = 'id2749957-1554-tr'><td ID = 'id2749959-1554-td'>
                                                              400 W SCWA</td><td ID = 'id2749965-1556-td'>
                                                              456</td><td ID = 'id2749972-1558-td'>
                                                              </td><td ID = 'id2749978-1560-td'>
                                                              Medium</td><td ID = 'id2749985-1562-td'>
                                                              50</td><td ID = 'id2749991-1564-td'>
                                                              120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id2749999-1567-tr'><td ID = 'id2750001-1567-td'>
                                                              350 W SCWA</td><td ID = 'id2750008-1569-td'>
                                                              400</td><td ID = 'id2750014-1571-td'>
                                                              </td><td ID = 'id2750020-1573-td'>
                                                              Medium</td><td ID = 'id2750027-1575-td'>
                                                              40</td><td ID = 'id2750033-1577-td'>
                                                              120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id2750041-1580-tr'><td ID = 'id2750043-1580-td'>
                                                              400 W LLRPSL</td><td ID = 'id2750050-1582-td'>
                                                              425</td><td ID = 'id2750056-1584-td'>
                                                              </td><td ID = 'id2750062-1586-td'>
                                                              Low</td><td ID = 'id2750069-1588-td'>
                                                              25</td><td ID = 'id2750076-1590-td'>
                                                              277</td></tr><tr ID = 'id2750083-1593-tr'><td ID = 'id2750085-1593-td'>
                                                              350 W LLRPSL</td><td ID = 'id2750092-1595-td'>
                                                              375</td><td ID = 'id2750098-1597-td'>
                                                              </td><td ID = 'id2750105-1599-td'>
                                                              Low</td><td ID = 'id2750111-1601-td'>
                                                              25</td><td ID = 'id2750118-1603-td'>
                                                              277</td></tr><tr ID = 'id2750125-1606-tr'><td ID = 'id2750127-1606-td'>
                                                              400 W RLB</td><td ID = 'id2750134-1608-td'>
                                                              465</td><td ID = 'id2750141-1610-td'>
                                                              </td><td ID = 'id2750147-1612-td'>
                                                              High</td><td ID = 'id2750154-1614-td'>
                                                              45-50</td><td ID = 'id2750160-1616-td'>
                                                              120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id2750168-1619-tr'><td ID = 'id2750170-1619-td'>
                                                              250 W RLB</td><td ID = 'id2750177-1621-td'>
                                                              298</td><td ID = 'id2750183-1623-td'>
                                                              </td><td ID = 'id2750190-1625-td'>
                                                              High</td><td ID = 'id2750196-1627-td'>
                                                              30</td><td ID = 'id2750203-1629-td'>
                                                              120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id2750210-1632-tr'><td ID = 'id2750212-1632-td'>
                                                              175 W RLB</td><td ID = 'id2750219-1634-td'>
                                                              220</td><td ID = 'id2750226-1636-td'>
                                                              </td><td ID = 'id2750232-1638-td'>
                                                              High</td><td ID = 'id2750239-1640-td'>
                                                              30</td><td ID = 'id2750245-1642-td'>
                                                              120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id2750253-1645-tr'><td ID = 'id2750255-1645-td'>
                                                              High pressure sodium </td></tr><tr ID = 'id2750265-1650-tr'><td ID = 'id2750267-1650-td'>
                                                              400 W CWA</td><td ID = 'id2750274-1652-td'>
                                                              457</td><td ID = 'id2750280-1654-td'>
                                                              </td><td ID = 'id2750286-1656-td'>
                                                              Med-high</td><td ID = 'id2750293-1658-td'>
                                                              40</td><td ID = 'id2750300-1660-td'>
                                                              120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id2750307-1663-tr'><td ID = 'id2750309-1663-td'></td><td ID = 'id2750314-1665-td'></td><td ID = 'id2750320-1667-td'></td><td ID = 'id2750325-1669-td'></td><td ID = 'id2750330-1671-td'></td><td ID = 'id2750336-1673-td'></td></tr><tr ID = 'id2750342-1676-tr'><td ID = 'id2750344-1676-td'>
                                                              250 W CWA</td><td ID = 'id2750351-1678-td'>
                                                              295</td><td ID = 'id2750358-1680-td'>
                                                              </td><td ID = 'id2750364-1682-td'>
                                                              Med-high</td><td ID = 'id2750371-1684-td'>
                                                              30</td><td ID = 'id2750377-1686-td'>
                                                              120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id2750385-1689-tr'><td ID = 'id2750387-1689-td'>
                                                              400 W MRB</td><td ID = 'id2750393-1691-td'>
                                                              480</td><td ID = 'id2750400-1693-td'>
                                                              </td><td ID = 'id2750406-1695-td'>
                                                              High</td><td ID = 'id2750413-1697-td'>
                                                              45</td><td ID = 'id2750420-1699-td'>
                                                              120, 208, 240, 277, 480</td></tr></tbody></table>
                                                              1Some international applications require 50-Hz equipment and different voltages. Consult ballast and lamp manufacturer.
                                                              Ballast information for fluorescent lamps
                                                              <table ID = 'id2750452-1711-table' CELLSPACING = '0' CELLPADDING = '3' BORDER = '1' STYLE = 'background-color: #FFFFFF'><tbody ID = 'id2750463-1711-tbody'><tr ID = 'id2750465-1711-tr'><td ID = 'id2750467-1711-td' VALIGN = 'top' STYLE = 'background-color: #F8F2E6'></td></tr><tr ID = 'id2750474-1713-tr'>Lamp typesMagnetic T12, T8Electronic T12, T8</tr><tr ID = 'id2750497-1720-tr'><td ID = 'id2750499-1720-td'>
                                                              Typical lumens/W with T8 lamps (4-ft length)</td><td ID = 'id2750506-1722-td'>
                                                              72</td><td ID = 'id2750513-1724-td'>
                                                              86</td></tr><tr ID = 'id2750520-1727-tr'><td ID = 'id2750522-1727-td'>
                                                              Operating frequency</td><td ID = 'id2750529-1729-td'>
                                                              60 Hz</td><td ID = 'id2750536-1731-td'>
                                                              20-25 kHz</td></tr><tr ID = 'id2750543-1734-tr'><td ID = 'id2750546-1734-td'>
                                                              Causes stroboscopic effect</td><td ID = 'id2750552-1736-td'>
                                                              Yes, moderate</td><td ID = 'id2750559-1738-td'>
                                                              No</td></tr><tr ID = 'id2750566-1741-tr'><td ID = 'id2750568-1741-td'>
                                                              Sound rating</td><td ID = 'id2750575-1743-td'>
                                                              A-D</td><td ID = 'id2750582-1745-td'>
                                                              A+</td></tr><tr ID = 'id2750589-1748-tr'><td ID = 'id2750591-1748-td'>
                                                              Operating temperature ratio</td><td ID = 'id2750598-1750-td'>
                                                              Base</td><td ID = 'id2750604-1752-td'>
                                                              12% cooler</td></tr><tr ID = 'id2750612-1755-tr'><td ID = 'id2750614-1755-td'>
                                                              Typical harmonic distortion</td><td ID = 'id2750621-1757-td'>
                                                              15-30%</td><td ID = 'id2750627-1759-td'>
                                                              m20%</td></tr><tr ID = 'id2750635-1762-tr'><td ID = 'id2750637-1762-td'>
                                                              Allowable line voltage variation the ballast can withstand and still properly operate the lamp</td><td ID = 'id2750645-1764-td'>
                                                              </td><td ID = 'id2750651-1766-td'>
