Lamp and ballast guide
Industrial lighting varies widely by environment and application. From control room to laboratory to warehouse, each has its own lighting requirements. This article describes lamp types and uses, ballast data, and how to specify the proper lighting for industrial areas.
07/06/2001
Plant Engineering - December 2000
LIGHTING
Reference File: Lamp and ballast guide
Sidebar:
HID ballast terminology
Tables:
  • Lighting warehouse areas
  • Fluorescent lamp data
  • IESNA recommended lighting levels
  • HID lamp data
  • Ballast information for HID
  • Ballast information for fluorescent lamps
    • Jack Smith, Senior Editor, PLANT ENGINEERING Magazine
      • Lighting industrial areas
      • Lamp types and uses
      • Ballast data
        • Industrial lighting varies widely by environment and application. Workplaces range from control room to laboratory to warehouse. Each has its own lighting requirements.
          The industrial workplace environment is divided into two general categories—low bay and high bay. Areas where the luminaire is less than 20-ft above the floor are considered low bay, while areas where the luminaire is more than 20-ft above the floor are high bay. Low bay fixtures should spread light and reduce glare, while high bay units should concentrate light with a medium spread and prominent downward light component.
          Luminance — also called brightness — is light emitted from a surface. It is measured in candelas per square meter. Luminance levels should be kept uniform to prevent worker eyestrain and fatigue, which could affect productivity. Also, accidents could occur when moving between areas not uniformly illuminated.
          Lumen output of a lamp at approximately 100 hr of operation is known as initial lumens. The output of a lamp after it has operated for approximately 40% of its rated life is known as mean lumens.
          Color temperature describes the appearance of the lamp source measured in deg Kelvin. High numbers are considered cool and blue in appearance. Low numbers are warm and red/yellow in appearance.
          Color rendering index (CRI) measures on a scale of 1%%MDASSML%%100 how accurately colors appear under a certain source. The most accurate rendering is 100.
          Lamp efficacy is measured in lumens per Watt and is the efficiency of the lamp. Like miles per gallon, the higher the number, the better the energy efficiency.
          Ballasts
          Arc discharge lamps, such as HID and fluorescent, require ballasts to establish the arc and maintain electrical current once the arc is struck. Ballasts also compensate for voltage variations.
          Magnetic and electronic ballasts are available for fluorescent lighting systems. Ongoing developments in both lamps and ballasts are improving their efficiencies and extending their lives. Both translate to cost reductions in your plant.
          The effects of temperature on the life expectancy of a ballast and its components are shown in the accompany graph .
          Typical industrial facility areas
          • Production
          • Inspection
          • Warehouses
          • Offices
          • Public areas
          • Laboratories
          • Clean rooms
          • Control rooms
            • Critical lighting parameters
              • Adequate lighting levels
              • Uniform illuminance
              • Vertical lighting
              • Glare reduction
              • Balance brightness
              • Appropriate color performance
              • Appropriate mounting heights
                • Recommended mounting heights for luminaires are shown in the accompanying illustration .
                  Plant Engineering Magazine extends its appreciation to Philips Lighting and Lithonia Lighting for the use of their material in the preparation of this article.
                  —Jack Smith, Senior Editor, 630-320-7147, jsmith@cahners.com
                  Sidebar:
                  Ballast regulation. Ability of a ballast to control lamp wattage, and therefore lamp output, when subjected to changes in line voltage.
                  Dip tolerance. Amount of line voltage drop a ballast can sustain before the lamp extinguishes. Usually expressed as a percentage; the higher the percentage, the better.
                  Ballast losses. Amount of additional energy a ballast consumes to operate the lamp (line Watts minus lamp Watts). There is usually a tradeoff between ballast losses and ballast regulation.
                  Constant wattage autotransformer (CWA). Lead-type regulator and the most widely used HID ballast. It offers good ballast regulation and moderate ballast losses. CWA is available for metal halide and high-pressure sodium lamps.
                  SCWA. Pulse-start version of the CWA ballast, but with greater lumen capabilities. Use on pulse-start metal halide lamps only.
                  LLRPSL. Low loss reactor used in areas with very little line voltage regulation. They are designed as an energy saving system. Use on pulse-start metal halide lamps only.
                  RLB. Regulated lag ballast (LAG-type regulator, "reg-lag") used in areas where line dip tolerance is critical. It exhibits the best ballast regulation. Use on pulse-start metal halide lamps only.
                  MRB. Magnetic regulated ballast referred to as a regulated or stabilized type, has operating characteristics similar to the RLB. Use on high-pressure sodium sources only.
                  [ Back to top ]
                  <table ID = 'id4522037-147-table' CELLSPACING = '0' CELLPADDING = '3' BORDER = '1' STYLE = 'background-color: #FFFFFF'><tbody ID = 'id4522047-147-tbody'><tr ID = 'id4522049-147-tr'><td ID = 'id4522051-147-td' VALIGN = 'top' STYLE = 'background-color: #F8F2E6'></td></tr><tr ID = 'id4522059-149-tr'>Open areasFootcandles on floor</tr><tr ID = 'id4522075-154-tr'><td ID = 'id4522077-154-td'>
                  Receipt/dispatch </td><td ID = 'id4522085-158-td'></td></tr><tr ID = 'id4522092-161-tr'><td ID = 'id4522094-161-td'>
                  Loading bays</td><td ID = 'id4522100-163-td'>
                  15</td></tr><tr ID = 'id4522108-166-tr'><td ID = 'id4522110-166-td'>
                  Unpacking, sorting,</td></tr><tr ID = 'id4522117-169-tr'><td ID = 'id4522119-169-td'>
                  and control station</td><td ID = 'id4522126-171-td'>
                  20</td></tr><tr ID = 'id4522133-174-tr'><td ID = 'id4522135-174-td'>
                  Packing and dispatch</td><td ID = 'id4522142-176-td'>
                  30</td></tr><tr ID = 'id4522149-179-tr'><td ID = 'id4522151-179-td'>
                  Supervisor's desk</td><td ID = 'id4522158-181-td'>
                  50</td></tr><tr ID = 'id4522165-184-tr'><td ID = 'id4522167-184-td'>
                  Open areas </td><td ID = 'id4522176-188-td'></td></tr><tr ID = 'id4522182-191-tr'><td ID = 'id4522184-191-td'>
                  Large item storage</td><td ID = 'id4522191-193-td'>
                  10</td></tr><tr ID = 'id4522198-196-tr'><td ID = 'id4522200-196-td'>
                  Medium item storage</td><td ID = 'id4522207-198-td'>
                  20</td></tr><tr ID = 'id4522214-201-tr'><td ID = 'id4522216-201-td'>
                  Small item storage</td><td ID = 'id4522223-203-td'>
                  30</td></tr><tr ID = 'id4522230-206-tr'><td ID = 'id4522232-206-td'>
                  Rack areas </td><td ID = 'id4522241-210-td'>
                  Footcandles on racks </td></tr><tr ID = 'id4522251-215-tr'><td ID = 'id4522253-215-td'>
                  Manual racks </td><td ID = 'id4522261-219-td'></td></tr><tr ID = 'id4522268-222-tr'><td ID = 'id4522270-222-td'>
                  Large item storage</td><td ID = 'id4522276-224-td'>
                  10</td></tr><tr ID = 'id4522284-227-tr'><td ID = 'id4522286-227-td'>
                  Medium item storage</td><td ID = 'id4522292-229-td'>
                  20</td></tr><tr ID = 'id4522300-232-tr'><td ID = 'id4522302-232-td'>
                  Small item storage</td><td ID = 'id4522308-234-td'>
                  30</td></tr><tr ID = 'id4522316-237-tr'><td ID = 'id4522318-237-td'>
                  Self-service racks </td><td ID = 'id4522326-241-td'>
                  50</td></tr><tr ID = 'id4522334-244-tr'><td ID = 'id4522336-244-td'>
                  Automated racks, high-rise aisles </td><td ID = 'id4522344-248-td'>
                  20-50</td></tr></tbody></table>
                  <table ID = 'id4522382-262-table' CELLSPACING = '0' CELLPADDING = '3' BORDER = '1' STYLE = 'background-color: #FFFFFF'><tbody ID = 'id4522392-262-tbody'><tr ID = 'id4522395-262-tr'><td ID = 'id4522397-262-td' VALIGN = 'top' STYLE = 'background-color: #F8F2E6'></td></tr><tr ID = 'id4522404-264-tr'>Lamp typeInitial lumensMean lumensLumen depreciationLamp life, 3 hr/startColor rendering index (CRI)Lamp efficacy,</tr><tr ID = 'id4522452-279-tr'><td ID = 'id4522454-279-td'>
                  F40 T12 Energy saving</td><td ID = 'id4522460-281-td'>
                  2650</td><td ID = 'id4522467-283-td'>
                  2306</td><td ID = 'id4522473-285-td'>
                  0.87</td><td ID = 'id4522480-287-td'>
                  20,000</td><td ID = 'id4522486-289-td'>
                  60%%MDASSML%%70</td><td ID = 'id4522492-291-td'>
                  65</td></tr><tr ID = 'id4522500-294-tr'><td ID = 'id4522502-294-td'>
                  F40 T12 Energy saving high color</td><td ID = 'id4522508-296-td'>
                  2800</td><td ID = 'id4522515-298-td'>
                  2520</td><td ID = 'id4522521-300-td'>
                  0.90</td><td ID = 'id4522528-302-td'>
                  20,000</td><td ID = 'id4522534-304-td'>
                  70%%MDASSML%%80</td><td ID = 'id4522540-306-td'>
                  71</td></tr><tr ID = 'id4522548-309-tr'><td ID = 'id4522550-309-td'>
                  F32 T8</td><td ID = 'id4522556-311-td'>
                  2850</td><td ID = 'id4522563-313-td'>
                  2565</td><td ID = 'id4522569-315-td'>
                  0.90</td><td ID = 'id4522576-317-td'>
                  20,000</td><td ID = 'id4522582-319-td'>
                  75</td><td ID = 'id4522588-321-td'>
                  86</td></tr><tr ID = 'id4522596-324-tr'><td ID = 'id4522598-324-td'>
                  F32 T8 High color</td><td ID = 'id4522604-326-td'>
                  2950</td><td ID = 'id4522611-328-td'>
                  2655</td><td ID = 'id4522617-330-td'>
                  0.90</td><td ID = 'id4522624-332-td'>
                  20,000</td><td ID = 'id4522630-334-td'>
                  82%%MDASSML%%95</td><td ID = 'id4522636-336-td'>
                  89</td></tr><tr ID = 'id4522644-339-tr'><td ID = 'id4522646-339-td'>
                  F32 T8 Long life</td><td ID = 'id4522652-341-td'>
                  3000</td><td ID = 'id4522659-343-td'>
                  2850</td><td ID = 'id4522665-345-td'>
                  0.95</td><td ID = 'id4522672-347-td'>
                  24,000</td><td ID = 'id4522678-349-td'>
                  85</td><td ID = 'id4522684-351-td'>
                  95</td></tr><tr ID = 'id4522692-354-tr'><td ID = 'id4522694-354-td'>
                  Slimline </td></tr><tr ID = 'id4522704-359-tr'><td ID = 'id4522706-359-td'>
                  F48 T12</td><td ID = 'id4522712-361-td'>
                  2900</td><td ID = 'id4522719-363-td'>
                  2610</td><td ID = 'id4522725-365-td'>
                  0.90</td><td ID = 'id4522731-367-td'>
                  9000</td><td ID = 'id4522738-369-td'>
                  60%%MDASSML%%70</td><td ID = 'id4522744-371-td'>
                  54</td></tr><tr ID = 'id4522752-374-tr'><td ID = 'id4522754-374-td'>
                  F48 T12 Energy saving</td><td ID = 'id4522760-376-td'>
                  2400</td><td ID = 'id4522767-378-td'>
                  2160</td><td ID = 'id4522773-380-td'>
                  0.90</td><td ID = 'id4522779-382-td'>
                  9000</td><td ID = 'id4522786-384-td'>
                  62</td><td ID = 'id4522792-386-td'>
                  54</td></tr><tr ID = 'id4522800-389-tr'><td ID = 'id4522802-389-td'>
                  F96 T12 Energy saving</td><td ID = 'id4522808-391-td'>
                  5500</td><td ID = 'id4522815-393-td'>
                  4950</td><td ID = 'id4522821-395-td'>
                  0.90</td><td ID = 'id4522827-397-td'>
                  12,000</td><td ID = 'id4522834-399-td'>
                  60%%MDASSML%%70</td><td ID = 'id4522840-401-td'>
                  79</td></tr><tr ID = 'id4522848-404-tr'><td ID = 'id4522850-404-td'>
                  F96 T8</td><td ID = 'id4522856-406-td'>
                  5700</td><td ID = 'id4522863-408-td'>
                  5244</td><td ID = 'id4522869-410-td'>
                  0.92</td><td ID = 'id4522875-412-td'>
                  15,000</td><td ID = 'id4522882-414-td'>
                  75</td><td ID = 'id4522888-416-td'>
                  98</td></tr><tr ID = 'id4522896-419-tr'><td ID = 'id4522898-419-td'>
                  F96 T8 High color</td><td ID = 'id4522904-421-td'>
                  5900</td><td ID = 'id4522911-423-td'>
                  5369</td><td ID = 'id4522917-425-td'>
                  0.91</td><td ID = 'id4522923-427-td'>
                  15,000</td><td ID = 'id4522930-429-td'>
                  82%%MDASSML%%85</td><td ID = 'id4522936-431-td'>
                  100</td></tr><tr ID = 'id4522944-434-tr'><td ID = 'id4522946-434-td'>
                  High output </td></tr><tr ID = 'id4522955-439-tr'><td ID = 'id4522958-439-td'>
                  F48 T12 HO</td><td ID = 'id4522964-441-td'>
                  4050</td><td ID = 'id4522970-443-td'>
                  3483</td><td ID = 'id4522977-445-td'>
                  0.86</td><td ID = 'id4522983-447-td'>
                  12,000</td><td ID = 'id4522990-449-td'>
                  60%%MDASSML%%70</td><td ID = 'id4522996-451-td'>
                  51</td></tr><tr ID = 'id4523003-454-tr'><td ID = 'id4523006-454-td'>
                  Energy saving</td><td ID = 'id4523012-456-td'>
                  8000</td><td ID = 'id4523018-458-td'>
                  6960</td><td ID = 'id4523025-460-td'>
                  0.87</td><td ID = 'id4523031-462-td'>
                  12,000</td><td ID = 'id4523038-464-td'>
                  60%%MDASSML%%70</td><td ID = 'id4523044-466-td'>
                  67</td></tr><tr ID = 'id4523051-469-tr'><td ID = 'id4523054-469-td'>
                  F96 T8 HO</td><td ID = 'id4523060-471-td'>
                  8200</td><td ID = 'id4523066-473-td'>
                  7626</td><td ID = 'id4523073-475-td'>
                  0.93</td><td ID = 'id4523079-477-td'>
                  18,000</td><td ID = 'id4523086-479-td'>
                  75</td><td ID = 'id4523092-481-td'>
                  95</td></tr></tbody></table>
                  F numbers refer to wattage, where an F48 lamp is rated at 48 W.
                  <table ID = 'id4523144-500-table' CELLSPACING = '0' CELLPADDING = '3' BORDER = '1' STYLE = 'background-color: #FFFFFF'><tbody ID = 'id4523154-500-tbody'><tr ID = 'id4523156-500-tr'><td ID = 'id4523158-500-td' VALIGN = 'top' STYLE = 'background-color: #F8F2E6'></td></tr><tr ID = 'id4523165-502-tr'>Indoor activityAverage fcAverage lux</tr><tr ID = 'id4523188-509-tr'><td ID = 'id4523190-509-td'>
                  Assembly </td><td ID = 'id4523198-513-td'></td><td ID = 'id4523204-515-td'></td></tr><tr ID = 'id4523210-518-tr'><td ID = 'id4523212-518-td'>
                  Simple</td><td ID = 'id4523218-520-td'>
                  30</td><td ID = 'id4523225-522-td'>
                  300</td></tr><tr ID = 'id4523232-525-tr'><td ID = 'id4523234-525-td'>
                  Difficult</td><td ID = 'id4523241-527-td'>
                  100</td><td ID = 'id4523247-529-td'>
                  1000</td></tr><tr ID = 'id4523255-532-tr'><td ID = 'id4523257-532-td'>
                  Exacting</td><td ID = 'id4523263-534-td'>
                  300%%MDASSML%%-1000</td><td ID = 'id4523270-536-td'>
                  3000%%MDASSML%%10,000</td></tr><tr ID = 'id4523277-539-tr'><td ID = 'id4523279-539-td'>
                  Raw material processing (cleaning, cutting, crushing, sorting, grading, etc.) </td></tr><tr ID = 'id4523290-544-tr'><td ID = 'id4523292-544-td'>
                  Course</td><td ID = 'id4523298-546-td'>
                  10</td><td ID = 'id4523305-548-td'>
                  100</td></tr><tr ID = 'id4523312-551-tr'><td ID = 'id4523314-551-td'>
                  Medium</td><td ID = 'id4523321-553-td'>
                  30</td><td ID = 'id4523327-555-td'>
                  300</td></tr><tr ID = 'id4523334-558-tr'><td ID = 'id4523337-558-td'>
                  Fine</td><td ID = 'id4523343-560-td'>
                  50</td><td ID = 'id4523349-562-td'>
                  500</td></tr><tr ID = 'id4523357-565-tr'><td ID = 'id4523359-565-td'>
                  Very fine</td><td ID = 'id4523365-567-td'>
                  100</td><td ID = 'id4523372-569-td'>
                  1000</td></tr><tr ID = 'id4523379-572-tr'><td ID = 'id4523381-572-td'>
                  Inspection </td></tr><tr ID = 'id4523391-577-tr'><td ID = 'id4523393-577-td'>
                  Simple</td><td ID = 'id4523400-579-td'>
                  30</td><td ID = 'id4523406-581-td'>
                  300</td></tr><tr ID = 'id4523413-584-tr'><td ID = 'id4523416-584-td'>
                  Difficult</td><td ID = 'id4523422-586-td'>
                  100</td><td ID = 'id4523428-588-td'>
                  1000</td></tr><tr ID = 'id4523436-591-tr'><td ID = 'id4523438-591-td'>
                  Exacting</td><td ID = 'id4523444-593-td'>
                  300%%MDASSML%%1000</td><td ID = 'id4523451-595-td'>
                  3000%%MDASSML%%10,000</td></tr><tr ID = 'id4523458-598-tr'><td ID = 'id4523460-598-td'>
                  Material handling </td></tr><tr ID = 'id4523470-603-tr'><td ID = 'id4523472-603-td'>
                  Shipping and receiving</td><td ID = 'id4523478-605-td'>
                  30</td><td ID = 'id4523485-607-td'>
                  300</td></tr><tr ID = 'id4523492-610-tr'><td ID = 'id4523494-610-td'>
                  Wrapping, packing, labeling</td><td ID = 'id4523501-612-td'>
                  30</td><td ID = 'id4523507-614-td'>
                  300</td></tr><tr ID = 'id4523515-617-tr'><td ID = 'id4523517-617-td'>
                  Picking stock and classifying</td><td ID = 'id4523523-619-td'>
                  30</td><td ID = 'id4523530-621-td'>
                  300</td></tr><tr ID = 'id4523537-624-tr'><td ID = 'id4523539-624-td'>
                  Loading (inside truck)</td><td ID = 'id4523546-626-td'>
                  10</td><td ID = 'id4523552-628-td'>
                  100</td></tr><tr ID = 'id4523560-631-tr'><td ID = 'id4523562-631-td'>
                  Machining </td></tr><tr ID = 'id4523571-636-tr'><td ID = 'id4523573-636-td'>
                  Rough bench or machine work</td><td ID = 'id4523580-638-td'>
                  30</td><td ID = 'id4523586-640-td'>
                  300</td></tr><tr ID = 'id4523594-643-tr'><td ID = 'id4523596-643-td'>
                  Medium bench or machine work</td><td ID = 'id4523602-645-td'>
                  50</td><td ID = 'id4523609-647-td'>
                  500</td></tr><tr ID = 'id4523616-650-tr'><td ID = 'id4523618-650-td'>
                  Fine bench or machine work</td><td ID = 'id4523625-652-td'>
                  300%%MDASSML%%1000</td><td ID = 'id4523631-654-td'>
                  3000%%MDASSML%%10,000</td></tr><tr ID = 'id4523638-657-tr'><td ID = 'id4523641-657-td'>
                  Extra-fine bench or machine work</td><td ID = 'id4523647-659-td'>
                  300%%MDASSML%%1000</td><td ID = 'id4523653-661-td'>
                  3000%%MDASSML%%10,000</td></tr><tr ID = 'id4523661-664-tr'><td ID = 'id4523663-664-td'>
                  Storage rooms or warehouses </td></tr><tr ID = 'id4523673-669-tr'><td ID = 'id4523675-669-td'>
                  Inactive</td><td ID = 'id4523681-671-td'>
                  5</td><td ID = 'id4523688-673-td'>
                  50</td></tr><tr ID = 'id4523695-676-tr'><td ID = 'id4523697-676-td'>
                  Active, bulky items, large labels</td><td ID = 'id4523704-678-td'>
                  10</td><td ID = 'id4523710-680-td'>
                  100</td></tr><tr ID = 'id4523717-683-tr'><td ID = 'id4523720-683-td'>
                  Active, small items, small labels</td><td ID = 'id4523726-685-td'>
                  30</td><td ID = 'id4523732-687-td'>
                  300</td></tr><tr ID = 'id4523740-690-tr'><td ID = 'id4523742-690-td'>
                  Cleanrooms </td></tr><tr ID = 'id4523752-695-tr'><td ID = 'id4523754-695-td'>
                  Workspace</td><td ID = 'id4523760-697-td'>
                  80</td><td ID = 'id4523766-699-td'>
                  800</td></tr><tr ID = 'id4523774-702-tr'><td ID = 'id4523776-702-td'>
                  Food processing </td></tr><tr ID = 'id4523786-707-tr'><td ID = 'id4523788-707-td'>
                  Workroom</td><td ID = 'id4523794-709-td'>
                  30</td><td ID = 'id4523801-711-td'>
                  300</td></tr><tr ID = 'id4523808-714-tr'><td ID = 'id4523810-714-td'>
                  Inspection areas</td><td ID = 'id4523817-716-td'>
                  150</td><td ID = 'id4523823-718-td'>
                  1500</td></tr><tr ID = 'id4523830-721-tr'><td ID = 'id4523833-721-td'>
                  Outdoor activity</td><td ID = 'id4523839-723-td'>
                  Average fc, horizontal/vertical</td><td ID = 'id4523845-725-td'>
                  Average lux, horizontal/vertical</td></tr><tr ID = 'id4523853-728-tr'><td ID = 'id4523855-728-td'>
                  Building exteriors </td></tr><tr ID = 'id4523865-733-tr'><td ID = 'id4523867-733-td'>
                  Active entrances</td><td ID = 'id4523873-735-td'>
                  5/3</td><td ID = 'id4523880-737-td'>
                  50/30</td></tr><tr ID = 'id4523887-740-tr'><td ID = 'id4523889-740-td'>
                  Inactive entrances (normally locked)</td><td ID = 'id4523896-742-td'>
                  3/3</td><td ID = 'id4523902-744-td'>
                  30/30</td></tr><tr ID = 'id4523909-747-tr'><td ID = 'id4523912-747-td'>
                  Building surrounds</td><td ID = 'id4523918-749-td'>
                  5/3</td><td ID = 'id4523924-751-td'>
                  50/30</td></tr><tr ID = 'id4523932-754-tr'><td ID = 'id4523934-754-td'>
                  Storage yards </td></tr><tr ID = 'id4523944-759-tr'><td ID = 'id4523946-759-td'>
                  Active</td><td ID = 'id4523952-761-td'>
                  10/3</td><td ID = 'id4523958-763-td'>
                  100/30</td></tr><tr ID = 'id4523966-766-tr'><td ID = 'id4523968-766-td'>
                  Inactive</td><td ID = 'id4523974-768-td'>
                  1/0.3</td><td ID = 'id4523981-770-td'>
                  10/3</td></tr><tr ID = 'id4523988-773-tr'><td ID = 'id4523990-773-td'>
                  Building and monuments, floodlighting (vertical only)</td></tr><tr ID = 'id4524001-778-tr'><td ID = 'id4524003-778-td'>
                  Bright surroundings, light surface</td><td ID = 'id4524010-780-td'>
                  3</td><td ID = 'id4524016-782-td'>
                  30</td></tr><tr ID = 'id4524024-785-tr'><td ID = 'id4524026-785-td'>
                  Bright surroundings, dark surface</td><td ID = 'id4524032-787-td'>
                  0</td><td ID = 'id4524038-789-td'>
                  100</td></tr><tr ID = 'id4524046-792-tr'><td ID = 'id4524048-792-td'>
                  Dark surroundings, light surface</td><td ID = 'id4524054-794-td'>
                  3</td><td ID = 'id4524061-796-td'>
                  30</td></tr><tr ID = 'id4524068-799-tr'><td ID = 'id4524070-799-td'>
                  Dark surroundings, dark surface</td><td ID = 'id4524077-801-td'>
                  3</td><td ID = 'id4524083-803-td'>
                  30</td></tr><tr ID = 'id4524091-806-tr'><td ID = 'id4524093-806-td'>
                  HID lamp data
                  <table ID = 'id4524133-820-table' CELLSPACING = '0' CELLPADDING = '3' BORDER = '1' STYLE = 'background-color: #FFFFFF'><tbody ID = 'id4524143-820-tbody'><tr ID = 'id4524145-820-tr'><td ID = 'id4524147-820-td' VALIGN = 'top' STYLE = 'background-color: #F8F2E6'></td></tr><tr ID = 'id4524154-822-tr'>Nominal lamp wattageInitial lumensMean lumensLamp life, 10 hr/startColor rendering index (CRI)Typical startup, minTypical restrike, minLamp efficiency, means lumens/W</tr><tr ID = 'id4524209-839-tr'><td ID = 'id4524211-839-td'>
                  Metal halide - clear </td></tr><tr ID = 'id4524220-844-tr'><td ID = 'id4524222-844-td'>
                  175</td><td ID = 'id4524229-846-td'>
                  14,000</td><td ID = 'id4524235-848-td'>
                  12,000</td><td ID = 'id4524242-850-td'>
                  10,000</td><td ID = 'id4524248-852-td'>
                  65</td><td ID = 'id4524254-854-td'>
                  2%%MDASSML%%5</td><td ID = 'id4524261-856-td'>
                  10%%MDASSML%%15</td><td ID = 'id4524267-858-td'>
                  69</td></tr><tr ID = 'id4524275-861-tr'><td ID = 'id4524277-861-td'>
                  250</td><td ID = 'id4524283-863-td'>
                  22,000</td><td ID = 'id4524290-865-td'>
                  17,000</td><td ID = 'id4524296-867-td'>
                  10,000</td><td ID = 'id4524302-869-td'>
                  65</td><td ID = 'id4524309-871-td'>
                  2%%MDASSML%%5</td><td ID = 'id4524315-873-td'>
                  10%%MDASSML%%15</td><td ID = 'id4524322-875-td'>
                  68</td></tr><tr ID = 'id4524329-878-tr'><td ID = 'id4524331-878-td'>
                  400</td><td ID = 'id4524338-880-td'>
                  36,000</td><td ID = 'id4524344-882-td'>
                  25,000</td><td ID = 'id4524350-884-td'>
                  20,000</td><td ID = 'id4524357-886-td'>
                  65</td><td ID = 'id4524363-888-td'>
                  2%%MDASSML%%5</td><td ID = 'id4524370-890-td'>
                  10%%MDASSML%%15</td><td ID = 'id4524376-892-td'>
                  63</td></tr><tr ID = 'id4524384-895-tr'><td ID = 'id4524386-895-td'>
                  1000</td><td ID = 'id4524392-897-td'>
                  110,000</td><td ID = 'id4524398-899-td'>
                  88,000</td><td ID = 'id4524405-901-td'>
                  12,000</td><td ID = 'id4524411-903-td'>
                  65</td><td ID = 'id4524418-905-td'>
                  2%%MDASSML%%5</td><td ID = 'id4524424-907-td'>
                  10%%MDASSML%%15</td><td ID = 'id4524430-909-td'>
                  88</td></tr><tr ID = 'id4524438-912-tr'><td ID = 'id4524440-912-td'>
                  Metal halide - coated </td></tr><tr ID = 'id4524450-917-tr'><td ID = 'id4524452-917-td'>
                  175</td><td ID = 'id4524458-919-td'>
                  14,000</td><td ID = 'id4524465-921-td'>
                  10,000</td><td ID = 'id4524471-923-td'>
                  10,000</td><td ID = 'id4524477-925-td'>
                  70</td><td ID = 'id4524484-927-td'>
                  2%%MDASSML%%5</td><td ID = 'id4524490-929-td'>
                  10%%MDASSML%%15</td><td ID = 'id4524497-931-td'>
                  57</td></tr><tr ID = 'id4524504-934-tr'><td ID = 'id4524506-934-td'>
                  250</td><td ID = 'id4524513-936-td'>
                  21,500</td><td ID = 'id4524519-938-td'>
                  17,000</td><td ID = 'id4524525-940-td'>
                  10,000</td><td ID = 'id4524532-942-td'>
                  70</td><td ID = 'id4524538-944-td'>
                  2%%MDASSML%%5</td><td ID = 'id4524545-946-td'>
                  10%%MDASSML%%15</td><td ID = 'id4524551-948-td'>
                  68</td></tr><tr ID = 'id4524558-951-tr'><td ID = 'id4524561-951-td'>
                  400</td><td ID = 'id4524567-953-td'>
                  36,000</td><td ID = 'id4524573-955-td'>
                  25,000</td><td ID = 'id4524580-957-td'>
                  20,000</td><td ID = 'id4524586-959-td'>
                  70</td><td ID = 'id4524593-961-td'>
                  2%%MDASSML%%5</td><td ID = 'id4524599-963-td'>
                  10%%MDASSML%%15</td><td ID = 'id4524605-965-td'>
                  63</td></tr><tr ID = 'id4524613-968-tr'><td ID = 'id4524615-968-td'>
                  1000</td><td ID = 'id4524621-970-td'>
                  107,000</td><td ID = 'id4524628-972-td'>
                  85,000</td><td ID = 'id4524634-974-td'>
                  12,000</td><td ID = 'id4524641-976-td'>
                  70</td><td ID = 'id4524647-978-td'>
                  2%%MDASSML%%5</td><td ID = 'id4524654-980-td'>
                  10%%MDASSML%%15</td><td ID = 'id4524661-982-td'>
                  85</td></tr><tr ID = 'id4524668-985-tr'><td ID = 'id4524670-985-td'>
                  Metal halide high output - clear </td></tr><tr ID = 'id4524680-990-tr'><td ID = 'id4524682-990-td'>
                  400</td><td ID = 'id4524689-992-td'>
                  44,000</td><td ID = 'id4524695-994-td'>
                  34,000</td><td ID = 'id4524702-996-td'>
                  20,000</td><td ID = 'id4524709-998-td'>
                  65</td><td ID = 'id4524715-1000-td'>
                  2%%MDASSML%%5</td><td ID = 'id4524722-1002-td'>
                  10%%MDASSML%%15</td><td ID = 'id4524728-1004-td'>
                  85</td></tr><tr ID = 'id4524736-1007-tr'><td ID = 'id4524738-1007-td'>
                  Pulse start metal halide (requires special ballast and ignitor)</td></tr><tr ID = 'id4524750-1012-tr'><td ID = 'id4524752-1012-td'>
                  70</td><td ID = 'id4524758-1014-td'>
                  5500</td><td ID = 'id4524765-1016-td'>
                  4070</td><td ID = 'id4524772-1018-td'>
                  12,000</td><td ID = 'id4524778-1020-td'>
                  65</td><td ID = 'id4524785-1022-td'>
                  2</td><td ID = 'id4524791-1024-td'>
                  3%%MDASSML%%4</td><td ID = 'id4524798-1026-td'>
                  58</td></tr><tr ID = 'id4524806-1029-tr'><td ID = 'id4524808-1029-td'>
                  100</td><td ID = 'id4524814-1031-td'>
                  9000</td><td ID = 'id4524821-1033-td'>
                  6390</td><td ID = 'id4524828-1035-td'>
                  15,000</td><td ID = 'id4524834-1037-td'>
                  65</td><td ID = 'id4524841-1039-td'>
                  2</td><td ID = 'id4524847-1041-td'>
                  3%%MDASSML%%4</td><td ID = 'id4524854-1043-td'>
                  64</td></tr><tr ID = 'id4524861-1046-tr'><td ID = 'id4524864-1046-td'>
                  150</td><td ID = 'id4524870-1048-td'>
                  15,000</td><td ID = 'id4524877-1050-td'>
                  11,300</td><td ID = 'id4524883-1052-td'>
                  15,000</td><td ID = 'id4524890-1054-td'>
                  65</td><td ID = 'id4524896-1056-td'>
                  2</td><td ID = 'id4524903-1058-td'>
                  3%%MDASSML%%4</td><td ID = 'id4524909-1060-td'>
                  75</td></tr><tr ID = 'id4524917-1063-tr'><td ID = 'id4524919-1063-td'>
                  200</td><td ID = 'id4524926-1065-td'>
                  21,000</td><td ID = 'id4524932-1067-td'>
                  15,800</td><td ID = 'id4524939-1069-td'>
                  15,000</td><td ID = 'id4524946-1071-td'>
                  65</td><td ID = 'id4524952-1073-td'>
                  2</td><td ID = 'id4524958-1075-td'>
                  3%%MDASSML%%4</td><td ID = 'id4524965-1077-td'>
                  79</td></tr><tr ID = 'id4524973-1080-tr'><td ID = 'id4524975-1080-td'>
                  320</td><td ID = 'id4524981-1082-td'>
                  32,000</td><td ID = 'id4524988-1084-td'>
                  21,200</td><td ID = 'id4524995-1086-td'>
                  20,000</td><td ID = 'id4525001-1088-td'>
                  65</td><td ID = 'id4525008-1090-td'>
                  2</td><td ID = 'id4525014-1092-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525021-1094-td'>
                  66</td></tr><tr ID = 'id4525028-1097-tr'><td ID = 'id4525030-1097-td'>
                  350</td><td ID = 'id4525037-1099-td'>
                  36,000</td><td ID = 'id4525044-1101-td'>
                  27,000</td><td ID = 'id4525050-1103-td'>
                  20,000</td><td ID = 'id4525057-1105-td'>
                  65</td><td ID = 'id4525063-1107-td'>
                  2</td><td ID = 'id4525070-1109-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525076-1111-td'>
                  77</td></tr><tr ID = 'id4525084-1114-tr'><td ID = 'id4525086-1114-td'>
                  400</td><td ID = 'id4525092-1116-td'>
                  44,000</td><td ID = 'id4525099-1118-td'>
                  37,400</td><td ID = 'id4525106-1120-td'>
                  30,000</td><td ID = 'id4525112-1122-td'>
                  65</td><td ID = 'id4525119-1124-td'>
                  2</td><td ID = 'id4525125-1126-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525132-1128-td'>
                  94</td></tr><tr ID = 'id4525140-1131-tr'><td ID = 'id4525142-1131-td'>
                  Pulse start metal halide (requires special ballast and ignitor)</td></tr><tr ID = 'id4525153-1136-tr'><td ID = 'id4525155-1136-td'>
                  150</td><td ID = 'id4525162-1138-td'>
                  14,250</td><td ID = 'id4525168-1140-td'>
                  10,300</td><td ID = 'id4525175-1142-td'>
                  15,000</td><td ID = 'id4525182-1144-td'>
                  70</td><td ID = 'id4525188-1146-td'>
                  2</td><td ID = 'id4525195-1148-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525201-1150-td'>
                  69</td></tr><tr ID = 'id4525209-1153-tr'><td ID = 'id4525211-1153-td'>
                  200</td><td ID = 'id4525217-1155-td'>
                  20,000</td><td ID = 'id4525224-1157-td'>
                  14,400</td><td ID = 'id4525231-1159-td'>
                  15,000</td><td ID = 'id4525237-1161-td'>
                  70</td><td ID = 'id4525244-1163-td'>
                  2</td><td ID = 'id4525250-1165-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525257-1167-td'>
                  72</td></tr><tr ID = 'id4525264-1170-tr'><td ID = 'id4525266-1170-td'>
                  350</td><td ID = 'id4525273-1172-td'>
                  34,500</td><td ID = 'id4525279-1174-td'>
                  24,900</td><td ID = 'id4525286-1176-td'>
                  20,000</td><td ID = 'id4525293-1178-td'>
                  70</td><td ID = 'id4525299-1180-td'>
                  2</td><td ID = 'id4525306-1182-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525312-1184-td'>
                  71</td></tr><tr ID = 'id4525320-1187-tr'><td ID = 'id4525322-1187-td'>
                  400</td><td ID = 'id4525328-1189-td'>
                  42,000</td><td ID = 'id4525335-1191-td'>
                  35,200</td><td ID = 'id4525342-1193-td'>
                  30,000</td><td ID = 'id4525348-1195-td'>
                  70</td><td ID = 'id4525355-1197-td'>
                  2</td><td ID = 'id4525361-1199-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525368-1201-td'>
                  88</td></tr><tr ID = 'id4525375-1204-tr'><td ID = 'id4525377-1204-td'>
                  Pulse start metal halide reg-lag (requires special reg-lag ballast and ignitor)</td></tr><tr ID = 'id4525389-1209-tr'><td ID = 'id4525391-1209-td'>
                  250</td><td ID = 'id4525398-1211-td'>
                  23,750</td><td ID = 'id4525404-1213-td'>
                  19,000</td><td ID = 'id4525411-1215-td'>
                  20,000</td><td ID = 'id4525418-1217-td'>
                  65</td><td ID = 'id4525424-1219-td'>
                  2</td><td ID = 'id4525430-1221-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525437-1223-td'>
                  76</td></tr><tr ID = 'id4525444-1226-tr'><td ID = 'id4525447-1226-td'>
                  400</td><td ID = 'id4525453-1228-td'>
                  44,000</td><td ID = 'id4525460-1230-td'>
                  37,400</td><td ID = 'id4525466-1232-td'>
                  30,000</td><td ID = 'id4525473-1234-td'>
                  65</td><td ID = 'id4525479-1236-td'>
                  2</td><td ID = 'id4525486-1238-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525492-1240-td'>
                  94</td></tr><tr ID = 'id4525500-1243-tr'><td ID = 'id4525502-1243-td'>
                  Pulse start metal halide reg-lag (requires special reg-lag ballast and ignitor)</td></tr><tr ID = 'id4525514-1248-tr'><td ID = 'id4525516-1248-td'>
                  250</td><td ID = 'id4525522-1250-td'>
                  22,600</td><td ID = 'id4525529-1252-td'>
                  17,500</td><td ID = 'id4525536-1254-td'>
                  20,000</td><td ID = 'id4525542-1256-td'>
                  70</td><td ID = 'id4525549-1258-td'>
                  2</td><td ID = 'id4525555-1260-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525562-1262-td'>
                  70</td></tr><tr ID = 'id4525569-1265-tr'><td ID = 'id4525571-1265-td'>
                  400</td><td ID = 'id4525578-1267-td'>
                  42,000</td><td ID = 'id4525584-1269-td'>
                  35,200</td><td ID = 'id4525591-1271-td'>
                  30,000</td><td ID = 'id4525598-1273-td'>
                  70</td><td ID = 'id4525604-1275-td'>
                  2</td><td ID = 'id4525611-1277-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525617-1279-td'>
                  88</td></tr><tr ID = 'id4525625-1282-tr'><td ID = 'id4525627-1282-td'>
                  High pressure sodium - clear </td></tr><tr ID = 'id4525637-1287-tr'><td ID = 'id4525639-1287-td'>
                  70</td><td ID = 'id4525645-1289-td'>
                  6400</td><td ID = 'id4525652-1291-td'>
                  5440</td><td ID = 'id4525659-1293-td'>
                  24,000</td><td ID = 'id4525665-1295-td'>
                  20%%MDASSML%%25</td><td ID = 'id4525672-1297-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525679-1299-td'>
                  1%%MDASSML%%2</td><td ID = 'id4525685-1301-td'>
                  78</td></tr><tr ID = 'id4525693-1304-tr'><td ID = 'id4525695-1304-td'>
                  100</td><td ID = 'id4525701-1306-td'>
                  9500</td><td ID = 'id4525708-1308-td'>
                  8550</td><td ID = 'id4525715-1310-td'>
                  24,000</td><td ID = 'id4525721-1312-td'>
                  20%%MDASSML%%25</td><td ID = 'id4525728-1314-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525735-1316-td'>
                  1%%MDASSML%%2</td><td ID = 'id4525741-1318-td'>
                  86</td></tr><tr ID = 'id4525749-1321-tr'><td ID = 'id4525751-1321-td'>
                  150</td><td ID = 'id4525757-1323-td'>
                  16,000</td><td ID = 'id4525764-1325-td'>
                  14,400</td><td ID = 'id4525771-1327-td'>
                  24,000</td><td ID = 'id4525777-1329-td'>
                  20%%MDASSML%%25</td><td ID = 'id4525784-1331-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525791-1333-td'>
                  1%%MDASSML%%2</td><td ID = 'id4525797-1335-td'>
                  96</td></tr><tr ID = 'id4525805-1338-tr'><td ID = 'id4525807-1338-td'>
                  200</td><td ID = 'id4525813-1340-td'>
                  22,000</td><td ID = 'id4525820-1342-td'>
                  19,600</td><td ID = 'id4525827-1344-td'>
                  24,000</td><td ID = 'id4525833-1346-td'>
                  20%%MDASSML%%25</td><td ID = 'id4525840-1348-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525847-1350-td'>
                  1%%MDASSML%%2</td><td ID = 'id4525853-1352-td'>
                  98</td></tr><tr ID = 'id4525861-1355-tr'><td ID = 'id4525863-1355-td'>
                  250</td><td ID = 'id4525869-1357-td'>
                  28,000</td><td ID = 'id4525876-1359-td'>
                  25,200</td><td ID = 'id4525883-1361-td'>
                  24,000</td><td ID = 'id4525889-1363-td'>
                  20%%MDASSML%%25</td><td ID = 'id4525896-1365-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525903-1367-td'>
                  1%%MDASSML%%2</td><td ID = 'id4525909-1369-td'>
                  101</td></tr><tr ID = 'id4525917-1372-tr'><td ID = 'id4525919-1372-td'>
                  310</td><td ID = 'id4525925-1374-td'>
                  37,000</td><td ID = 'id4525932-1376-td'>
                  33,300</td><td ID = 'id4525939-1378-td'>
                  24,000</td><td ID = 'id4525945-1380-td'>
                  20%%MDASSML%%25</td><td ID = 'id4525952-1382-td'>
                  3%%MDASSML%%4</td><td ID = 'id4525959-1384-td'>
                  1%%MDASSML%%2</td><td ID = 'id4525965-1386-td'>
                  107</td></tr><tr ID = 'id4525973-1389-tr'><td ID = 'id4525975-1389-td'>
                  350</td><td ID = 'id4525981-1391-td'>
                  46,500</td><td ID = 'id4525988-1393-td'>
                  44,000</td><td ID = 'id4525995-1395-td'>
                  24,000</td><td ID = 'id4526001-1397-td'>
                  20%%MDASSML%%25</td><td ID = 'id4526008-1399-td'>
                  3%%MDASSML%%4</td><td ID = 'id4526015-1401-td'>
                  1%%MDASSML%%2</td><td ID = 'id4526021-1403-td'>
                  126</td></tr><tr ID = 'id4526029-1406-tr'><td ID = 'id4526031-1406-td'>
                  400</td><td ID = 'id4526037-1408-td'>
                  50,000</td><td ID = 'id4526044-1410-td'>
                  45,000</td><td ID = 'id4526051-1412-td'>
                  24,000</td><td ID = 'id4526057-1414-td'>
                  20%%MDASSML%%25</td><td ID = 'id4526064-1416-td'>
                  3%%MDASSML%%4</td><td ID = 'id4526071-1418-td'>
                  1%%MDASSML%%2</td><td ID = 'id4526077-1420-td'>
                  113</td></tr><tr ID = 'id4526085-1423-tr'><td ID = 'id4526087-1423-td'>
                  1000</td><td ID = 'id4526094-1425-td'>
                  140,000</td><td ID = 'id4526100-1427-td'>
                  126,000</td><td ID = 'id4526107-1429-td'>
                  24,000</td><td ID = 'id4526114-1431-td'>
                  20%%MDASSML%%25</td><td ID = 'id4526120-1433-td'>
                  3%%MDASSML%%4</td><td ID = 'id4526127-1435-td'>
                  1%%MDASSML%%2</td><td ID = 'id4526134-1437-td'>
                  126</td></tr><tr ID = 'id4526141-1440-tr'><td ID = 'id4526143-1440-td'>
                  High pressure sodium - coated </td></tr><tr ID = 'id4526153-1445-tr'><td ID = 'id4526155-1445-td'>
                  70</td><td ID = 'id4526162-1447-td'>
                  5950</td><td ID = 'id4526168-1449-td'>
                  5058</td><td ID = 'id4526175-1451-td'>
                  24,000</td><td ID = 'id4526182-1453-td'>
                  20%%MDASSML%%25</td><td ID = 'id4526188-1455-td'>
                  3%%MDASSML%%4</td><td ID = 'id4526195-1457-td'>
                  1%%MDASSML%%2</td><td ID = 'id4526202-1459-td'>
                  72</td></tr><tr ID = 'id4526209-1462-tr'><td ID = 'id4526211-1462-td'>
                  100</td><td ID = 'id4526218-1464-td'>
                  8800</td><td ID = 'id4526224-1466-td'>
                  7920</td><td ID = 'id4526231-1468-td'>
                  24,000</td><td ID = 'id4526238-1470-td'>
                  20%%MDASSML%%25</td><td ID = 'id4526244-1472-td'>
                  3%%MDASSML%%4</td><td ID = 'id4526251-1474-td'>
                  1%%MDASSML%%2</td><td ID = 'id4526258-1476-td'>
                  79</td></tr><tr ID = 'id4526265-1479-tr'><td ID = 'id4526267-1479-td'>
                  150</td><td ID = 'id4526274-1481-td'>
                  15,000</td><td ID = 'id4526280-1483-td'>
                  13,500</td><td ID = 'id4526287-1485-td'>
                  24,000</td><td ID = 'id4526294-1487-td'>
                  20%%MDASSML%%25</td><td ID = 'id4526300-1489-td'>
                  3%%MDASSML%%4</td><td ID = 'id4526307-1491-td'>
                  1%%MDASSML%%2</td><td ID = 'id4526314-1493-td'>
                  90</td></tr><tr ID = 'id4526322-1496-tr'><td ID = 'id4526324-1496-td'>
                  250</td><td ID = 'id4526330-1498-td'>
                  26,000</td><td ID = 'id4526337-1500-td'>
                  23,400</td><td ID = 'id4526343-1502-td'>
                  24,000</td><td ID = 'id4526350-1504-td'>
                  20%%MDASSML%%25</td><td ID = 'id4526357-1506-td'>
                  3%%MDASSML%%4</td><td ID = 'id4526363-1508-td'>
                  1%%MDASSML%%2</td><td ID = 'id4526370-1510-td'>
                  94</td></tr><tr ID = 'id4526378-1513-tr'><td ID = 'id4526380-1513-td'>
                  400</td><td ID = 'id4526386-1515-td'>
                  47,500</td><td ID = 'id4526393-1517-td'>
                  42,750</td><td ID = 'id4526399-1519-td'>
                  24,000</td><td ID = 'id4526406-1521-td'>
                  20%%MDASSML%%25</td><td ID = 'id4526413-1523-td'>
                  3%%MDASSML%%4</td><td ID = 'id4526419-1525-td'>
                  1%%MDASSML%%2</td><td ID = 'id4526426-1527-td'>
                  107</td></tr></tbody></table>
                  <table ID = 'id4526471-1543-table' CELLSPACING = '0' CELLPADDING = '3' BORDER = '1' STYLE = 'background-color: #FFFFFF'><tbody ID = 'id4526481-1543-tbody'><tr ID = 'id4526483-1543-tr'><td ID = 'id4526485-1543-td' VALIGN = 'top' STYLE = 'background-color: #F8F2E6'></td></tr><tr ID = 'id4526493-1545-tr'>Ballast typeInput WBallast regulation line voltage/line wattageBallast lossesAverage dip tolerance, %Voltages</tr><tr ID = 'id4526537-1558-tr'><td ID = 'id4526539-1558-td'>
                  Metal halide </td></tr><tr ID = 'id4526549-1563-tr'><td ID = 'id4526551-1563-td'>
                  400 W CWA</td><td ID = 'id4526557-1565-td'>
                  458</td><td ID = 'id4526564-1567-td'>
                  </td><td ID = 'id4526571-1569-td'>
                  Medium</td><td ID = 'id4526577-1571-td'>
                  50</td><td ID = 'id4526584-1573-td'>
                  120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id4526592-1576-tr'><td ID = 'id4526594-1576-td'></td><td ID = 'id4526599-1578-td'></td><td ID = 'id4526604-1580-td'></td><td ID = 'id4526610-1582-td'></td><td ID = 'id4526615-1584-td'></td><td ID = 'id4526620-1586-td'></td></tr><tr ID = 'id4526627-1589-tr'><td ID = 'id4526629-1589-td'>
                  400 W SCWA</td><td ID = 'id4526636-1591-td'>
                  456</td><td ID = 'id4526642-1593-td'>
                  </td><td ID = 'id4526649-1595-td'>
                  Medium</td><td ID = 'id4526655-1597-td'>
                  50</td><td ID = 'id4526662-1599-td'>
                  120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id4526670-1602-tr'><td ID = 'id4526672-1602-td'>
                  350 W SCWA</td><td ID = 'id4526678-1604-td'>
                  400</td><td ID = 'id4526685-1606-td'>
                  </td><td ID = 'id4526692-1608-td'>
                  Medium</td><td ID = 'id4526698-1610-td'>
                  40</td><td ID = 'id4526705-1612-td'>
                  120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id4526713-1615-tr'><td ID = 'id4526715-1615-td'>
                  400 W LLRPSL</td><td ID = 'id4526721-1617-td'>
                  425</td><td ID = 'id4526728-1619-td'>
                  </td><td ID = 'id4526735-1621-td'>
                  Low</td><td ID = 'id4526741-1623-td'>
                  25</td><td ID = 'id4526748-1625-td'>
                  277</td></tr><tr ID = 'id4526755-1628-tr'><td ID = 'id4526758-1628-td'>
                  350 W LLRPSL</td><td ID = 'id4526764-1630-td'>
                  375</td><td ID = 'id4526771-1632-td'>
                  </td><td ID = 'id4526777-1634-td'>
                  Low</td><td ID = 'id4526784-1636-td'>
                  25</td><td ID = 'id4526790-1638-td'>
                  277</td></tr><tr ID = 'id4526798-1641-tr'><td ID = 'id4526800-1641-td'>
                  400 W RLB</td><td ID = 'id4526806-1643-td'>
                  465</td><td ID = 'id4526813-1645-td'>
                  </td><td ID = 'id4526820-1647-td'>
                  High</td><td ID = 'id4526827-1649-td'>
                  45%%MDASSML%%50</td><td ID = 'id4526833-1651-td'>
                  120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id4526841-1654-tr'><td ID = 'id4526843-1654-td'>
                  250 W RLB</td><td ID = 'id4526850-1656-td'>
                  298</td><td ID = 'id4526856-1658-td'>
                  </td><td ID = 'id4526863-1660-td'>
                  High</td><td ID = 'id4526870-1662-td'>
                  30</td><td ID = 'id4526876-1664-td'>
                  120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id4526884-1667-tr'><td ID = 'id4526886-1667-td'>
                  175 W RLB</td><td ID = 'id4526893-1669-td'>
                  220</td><td ID = 'id4526899-1671-td'>
                  </td><td ID = 'id4526906-1673-td'>
                  High</td><td ID = 'id4526912-1675-td'>
                  30</td><td ID = 'id4526919-1677-td'>
                  120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id4526927-1680-tr'><td ID = 'id4526929-1680-td'>
                  High pressure sodium </td></tr><tr ID = 'id4526939-1685-tr'><td ID = 'id4526941-1685-td'>
                  400 W CWA</td><td ID = 'id4526948-1687-td'>
                  457</td><td ID = 'id4526954-1689-td'>
                  </td><td ID = 'id4526961-1691-td'>
                  Med%%MDASSML%%high</td><td ID = 'id4526967-1693-td'>
                  40</td><td ID = 'id4526974-1695-td'>
                  120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id4526982-1698-tr'><td ID = 'id4526984-1698-td'></td><td ID = 'id4526989-1700-td'></td><td ID = 'id4526994-1702-td'></td><td ID = 'id4527000-1704-td'></td><td ID = 'id4527005-1706-td'></td><td ID = 'id4527010-1708-td'></td></tr><tr ID = 'id4527017-1711-tr'><td ID = 'id4527019-1711-td'>
                  250 W CWA</td><td ID = 'id4527026-1713-td'>
                  295</td><td ID = 'id4527032-1715-td'>
                  </td><td ID = 'id4527039-1717-td'>
                  Med%%MDASSML%%high</td><td ID = 'id4527046-1719-td'>
                  30</td><td ID = 'id4527052-1721-td'>
                  120, 208, 240, 277, 347, 480</td></tr><tr ID = 'id4527060-1724-tr'><td ID = 'id4527062-1724-td'>
                  400 W MRB</td><td ID = 'id4527069-1726-td'>
                  480</td><td ID = 'id4527076-1728-td'>
                  </td><td ID = 'id4527082-1730-td'>
                  High</td><td ID = 'id4527089-1732-td'>
                  45</td><td ID = 'id4527096-1734-td'>
                  120, 208, 240, 277, 480</td></tr></tbody></table>
                  <table ID = 'id4527139-1749-table' CELLSPACING = '0' CELLPADDING = '3' BORDER = '1' STYLE = 'background-color: #FFFFFF'><tbody ID = 'id4527149-1749-tbody'><tr ID = 'id4527151-1749-tr'><td ID = 'id4527154-1749-td' VALIGN = 'top' STYLE = 'background-color: #F8F2E6'></td></tr><tr ID = 'id4527161-1751-tr'>Lamp typesMagnetic T12, T8Electronic T12, T8</tr><tr ID = 'id4527184-1758-tr'><td ID = 'id4527186-1758-td'>
                  Typical lumens/W with T8 lamps (4-ft length)</td><td ID = 'id4527193-1760-td'>
                  72</td><td ID = 'id4527200-1762-td'>
                  86</td></tr><tr ID = 'id4527207-1765-tr'><td ID = 'id4527209-1765-td'>
                  Operating frequency</td><td ID = 'id4527216-1767-td'>
                  60 Hz</td><td ID = 'id4527223-1769-td'>
                  20%%MDASSML%%25 kHz</td></tr><tr ID = 'id4527230-1772-tr'><td ID = 'id4527233-1772-td'>
                  Causes stroboscopic effect</td><td ID = 'id4527239-1774-td'>
                  Yes, moderate</td><td ID = 'id4527246-1776-td'>
                  No</td></tr><tr ID = 'id4527254-1779-tr'><td ID = 'id4527256-1779-td'>
                  Sound rating</td><td ID = 'id4527262-1781-td'>
                  A%%MDASSML%%D</td><td ID = 'id4527269-1783-td'>
                  A+</td></tr><tr ID = 'id4527277-1786-tr'><td ID = 'id4527279-1786-td'>
                  Operating temperature ratio</td><td ID = 'id4527286-1788-td'>
                  Base</td><td ID = 'id4527292-1790-td'>
                  12% cooler</td></tr><tr ID = 'id4527300-1793-tr'><td ID = 'id4527302-1793-td'>
                  Typical harmonic distortion</td><td ID = 'id4527309-1795-td'>
                  15%%MDASSML%%30%</td><td ID = 'id4527316-1797-td'>
                  m20%</td></tr><tr ID = 'id4527323-1800-tr'><td ID = 'id4527326-1800-td'>
                  Allowable line voltage variation the ballast can withstand and still properly operate the lamp</td><td ID = 'id4527333-1802-td'>
                  </td><td ID = 'id4527340-1804-td'>
                  [ Back to top ]
