Keep that tower cool and clean
There are four potential problems to deal with in an open loop water management program: algae and slime, corrosion, scale deposits, and sediment/sludge.
There are four potential problems to deal with in an open loop water management program: algae and slime, corrosion, scale deposits, and sediment/sludge. These water quality problems can all be solved without any chemicals by using basic equipment technologies synthesized into an engineered system controlled through automation. The cooling tower water treatment system is designed for each application.
Aquaflo, Inc.
www.thomasregister.com/aquaflo
Circle 251
