Junction box with through-panel connections
Designed to consolidate wiring with inside panel cable or lead home run options, this junction box saves installation time by mounting one junction box instead of punching eight receptacle holes for through-panel signal connections.
M12 eurofast junction box saves installation time by mounting one junction box instead of punching eight receptacle holes for through-panel signal connections. The junction box is designed to consolidate wiring with inside panel cable or lead home run options to lessen the number of parts required and simplify the purchasing process. It is available with nickel plated brass or stainless steel insert threads. The junction box is equipped with outside the box signal and power LEDs, and is available with 8-ports and dual outputs. The boxes also provide an operating current of 4 A per port and 9 A total, with a 10 to 48-Vdc operating voltage. Nylon, fully encapsulated housings offer an IP67 protection rating when all receptacles are connected or covered with plugs.
