Isolated miniDIP dc/dc converters
The MG800xRW series provides 8W of output power in a space saving MiniDIP package. They are specifically designed to provide the compact size, high power density, I/O isolation and model selection required by a wide range of space critical board level applications.
By MicroPower Direct May 17, 2016
The MG800xRW series provides 8W of output power in a space saving MiniDIP package. They are specifically designed to provide the compact size, high power density, I/O isolation and model selection required by a wide range of space critical board level applications requiring miniature size, robust performance, and high power density. Each model is specified for operation over the wide operating temperature range of -40°C to +80°C with no heat sinking required. Cooling is by free air convection.
MicroPower Direct
www.micropowerdirect.com
