ISA88 Part 5 draft: Command, control, status, and functional strategy
We're seeking input on possible language in ISA88 Part 5 draft standard. Figures 6-12 follow, on functional strategy, and other concepts. Please provide comments to ensure the standard is understandable, appropriate, and useful across industries and areas of control, machine control, batch control, and continuous control, as well as flexible and scalable, across hybrid applications. See diagrams. Leave your comments.
05/13/2011
David ChappellA series of discussions follow seeking input on possible language in ISA88 Part 5 draft standard. Figures 6-12 follow with diabrams on functional strategy, and other concepts. Please provide comments to ensure the standard is understandable, appropriate, and useful across industries and areas of control, machine control, batch control, and continuous control, as well as flexible and scalable, across hybrid applications.
      Interactions between modules are generally not managed and are deeply imbedded within the FS as indicated in Figure 6: Traditional Modular Interactions.  In Module A of the Figure 6 example interaction with Module Z occurs from within the body of the FS automation and requires detailed knowledge of the interfaces provided by Module Z.
ISA88 Part 5 draft: Figure 6: Traditional Modular Interactions
  • Command and control can be implemented using simple logic or more sophisticated interfaces based on data types other than Boolean for exchange of command and control as represented in Figure 7 and Figure 8.
ISA88 Part 5 draft: Figure 7: Simple Logic Interface
ISA88 Part 5 draft: Figure 8: More Sophisticated Interface
  • Not all traditional implementations of commands by a module are fault tolerant, often providing little to no error checking or error recovery.
  • Not all modules are traditionally designed with a command and control interface that manages access by external entities as indicated in Figure 9: Interactions of multiple entities.
  • Traditional approaches generally require that if more than one entity requires the use of a module, those external entities must interact in a way that prevents unintended actions by the FS.
  • Traditional approaches often avoid using small reusable modules because they lack a standard approach for managing their interactions. Figure 10 and Figure 11 represent two approaches to automate the same system. The 2 module implementation minimizes module interaction where the 12 module implementation maximizes reusable modules.
ISA88 Part 5 draft: Figure 9: Interactions of multiple entities
Figure 11: Traditional Implementation with 12 modules
  • Figure 12: Some possible splits between Procedural and Basic ControlThe separation between equipment phase and equipment module procedural, coordination and basic control across modules is not always pure as represented in Figure 12. For the purposes of Part 5, procedural control is identified as any control that has a quiescent state that requires an external entity to issue a command to cause it to leave that state and carry out the intended functional strategy, at the conclusion of the execution of the functional strategy the quiescent state will be reentered.  Basic control does not have a quiescent state as part of its functional strategy and is capable of self direction from and to any state.
Do you understand the draft language? Is it useful across disciplines? Does anything confuse you or require additional explanations? Please comment below. Don't see the comment box? Click here and scroll down.
- David A. Chappell, Complete Manufacturing Automation associates - LLC
www.CMAa-LLC.com
chappell.da@gmail.com
Also read:
ISA88 Part 5 draft: Traditional automation designs for batch recipes
ISA88 Part 5 draft: Resource Manager implementation question, answer
Revised ISA88 Part 5 definitions
