iPhone app for motors
The BE$T application for iPhones can easily and accurately calculate an existing motor’s annual electricity usage based on its nominal efficiency and compare it to the annual electricity usage of Premium Efficient motors. It then recommends by catalog number, the appropriate motor for the application, and notes the payback period, in months, for replacing the existing motor.
The BE$T application for iPhones can easily and accurately calculate an existing motor’s annual electricity usage based on its nominal efficiency and compare it to the annual electricity usage of Premium Efficient motors. It then recommends by catalog number, the appropriate motor for the application, and notes the payback period, in months, for replacing the existing motor. The software is also capable of calculating and comparing yearly electrical savings when a variable speed drive is used vs. a constant speed motor.
Baldor www.baldor.com
