IP67 power connectors
A-size 3- and 4-pin 7/8 16UN powerfast connectors provide up to 600 V and 15 A of power in a modular wiring design. The IP67-rated connectors are designed to handle high-current applications for machine power distribution, while delivering resistance to vibration commonly associated with conveyors, motors and material handling applications.
A-size 3- and 4-pin 7/8 16UN powerfast connectors provide up to 600 V and 15 A of power in a modular wiring design. The IP67-rated connectors are designed to handle high-current applications for machine power distribution, while delivering resistance to vibration commonly associated with conveyors, motors and material handling applications. The connectors are available in cordsets with tray rated, exposed run PVC flexlife cable. The connector line offers male and female, straight connectors, standard and custom lengths, pigtails or extensions.
TURCK , www.turck.us
