I/O systems: Terminal extender cables, breakout boards
Mounting and wiring accessories include terminal extender cables, breakout boards, wiring harnesses, DIN-rail kits, jumper straps, rack adapters, and other components for Opto 22 automation, control, and I/O systems.
07/02/2008
Temecula, CAOpto 22 Snap Tex family of mounting and wiring accessories includes a wide variety of terminal extender cables, breakout boards, wiring harnesses, DIN-rail kits, jumper straps, rack adapters, and other components for
Opto 22 Snap Tex mounting and wiring accessories help with mounting and wiring automations, controls, I/O systems.
Opto 22 Snap Tex family of mounting and wiring accessories helps with mounting and wiring Opto 22 automation, control, and I/O systems.
Wiring, installing, and assembling control and I/O systems is often expensive and time-consuming for end-users, original equipment manufacturers (OEMs), panel builders, system integrators, and others, Opto 22 explains. Installers also must be careful to avoid mixing terminations, particularly in cases where several hundred devices terminate in a single cabinet, the company says, which is why it created the Snap Tex line—to significantly reduce the time, expense, and complexity associated with field instrumentation wiring and control cabinet assembly.
Opto 22 says:
-Snap Tex cables are 6 ft (1.8 m) long jacketed, pre-wired cables that provide neat, bundled connections from analog and digital I/O modules to field devices, terminal strips, and breakout boards. Snap Tex cables snap neatly into the tops of Snap I/O modules and terminate with color-coded flying leads, pre-stripped and tipped, ready for wiring. By providing snap-in, easy-to-trace wiring from the module to the device, Snap-Tex cables reduce wiring mistakes, protect terminal connections from dust and jarring, and also speed and simplify initial wiring, maintenance, and replacement. Three versions of Snap Tex cables are available, varying based on the internal bus connections required by the application. Customers have a choice of cables with even-numbered terminals commoned (Snap-Tex-CBE6), odd-numbered terminals commoned (Snap-Tex-CBO6), or with wiring straight through (Snap-Tex-CBS6).
-New breakout boards : The Snap-Tex-32 is a simple 32-channel breakout board with straight-through connections, designed primarily for use with Snap Tex cables and Snap analog or digital I/O modules. The Snap-Tex-FB16-H and Snap-Tex-FB16-L breakout boards offer 16-channel terminations and provide a fuse and a fuse-blown indicator for each channel. With the use of an external power supply, these breakout boards also bus power to loads. The Snap-Tex-F16-H facilitates 120-240 V, and the Snap-Tex-F16-L works with 12-24 V. These breakout boards are used for digital inputs and outputs. The Snap-Tex-MR10-16 and Snap-Tex-MR10-4 breakout boards are designed for high-current output switching. These boards feature mechanical relays that switch up to 10 amps per channel, expanding the switching ability of standard Snap I/O modules by 13 times. These boards include on/off indicators for each channel, and each can be wired as normally closed or normally open.
-Wiring and accessories : Wiring harnesses (used for connecting field devices to high-density Snap I/O modules), jumper connection straps (used with digital I/O modules), DIN-rail mounting kits, module removal tools, and other previously available accessories are moved under the Snap Tex line to help customers find the right parts for wiring and installation.
-Pricing, as of July 1 introduction and availability: The Snap-Tex-CBE6, Snap-Tex-CBO6, and Snap-Tex-CBS6 terminal extender cables are priced at $38 each. The Snap-Tex-32 breakout board is priced at $90. The Snap-Tex-FB16-H and Snap-Tex-FB16-L breakout boards are priced at $105. The Snap-Tex-MR10-16 breakout board is priced at $335. The Snap-Tex-MR10-4 breakout board is priced at $140. All cables, breakout boards and other Snap Tex mounting and wiring accessories are available now from the Opto 22 Website and through a global network of authorized Opto 22 distributors.
The new Snap Tex product line is “another example of our product research and development division responding to the stated needs of our customers,” says Mark Engman, Opto 22 president and CEO. “Many of our customers have expressed a desire for quicker, easier ways to mount and wire their I/O. Ultimately, Snap Tex, like all of our other product lines, is meant to provide the components, tools, and methods customers need to get their projects done faster, simpler, and in the manner they’re most comfortable with.”
– Edited by  Mark T. Hoske , editor in chief
Control Engineering News Desk
Register here and scroll down to select your choice of eNewsletters free .
World-class maintenance: The three keys to success - Deploy people, process and technology; 2016 Lubrication Guide; Why hydraulic systems get hot
Your leaks start here: Take a disciplined approach with your hydraulic system; U.S. presence at Hannover Messe a rousing success
Hannover Messe 2016: Taking hold of the future - Partner Country status spotlights U.S. manufacturing; Honoring manufacturing excellence: The 2015 Product of the Year Winners
The digital oilfield: Utilizing Big Data can yield big savings; Virtualization a real solution; Tracking SIS performance
Getting to the bottom of subsea repairs: Older pipelines need more attention, and operators need a repair strategy; OTC preview; Offshore production difficult - and crucial
Digital oilfields: Integrated HMI/SCADA systems enable smarter data acquisition; Real-world impact of simulation; Electric actuator technology prospers in production fields
Improving flowmeter calibration; Selecting flowmeters for natural gas; Case study: Streamlining assembly systems using PC-based control; CLPM: Improving process efficiency, throughput
Putting COPS into context; Designing medium-voltage electrical systems; Planning and designing resilient, efficient data centers; The nine steps of designing generator fuel systems
Warehouse winter comfort: The HTHV solution; Cooling with natural gas; Plastics industry booming
This article collection contains several articles on the vital role that compressed air plays in manufacturing plants.
