IO module with current and voltage signal combination
Turck's 4AI4AO-VI analog I/O module feature four analog inputs for current and four analog outputs for voltage.
Turck's 4AI4AO-VI analog I/O module is compatible with two of the company’s BL distributed I/O products: BL67 and BL Compact system. The module features four analog inputs for current or voltage and four analog outputs for voltage.
The 4AI4AO-VI is designed for use with Turck’s BL67 modular I/O system and BL Compact system. BL67 combines all of the flexibility of an in-the-cabinet I/O system with modularity, ruggedness and connectorization, while the BL Compact system is a revolutionary on-the-machine solution that obtains and transmits signals via diverse fieldbus protocols, without requiring a protective enclosure. Supporting both M8 and M12 I/O connectors and offering compatibility with a variety of communication protocols, such as Ethernet/IP, DeviceNet, CANopen and Modbus TCP, the BL family provides a high degree of I/O versatility for a wide range of applications.
The 4AI4AO-VI is constructed to withstand diverse environmental challenges. Operating in temperatures ranging from -40 to 70 degrees Celsius, rated to IP67 and UL listed, the module provides optimal performance in applications that yield extreme temperatures, moisture, shock or vibration—accommodating even the most demanding application requirements.
Turck
Also see: controleng.com/networks
