Interlocking safety switches for machine guards
IDEM INCH and MK1 series of interlocking safety switches are designed to fit leading edge, hinged, or lift-off machine guards.
08/23/2015
IDEM INCH and MK1 series of interlocking safety switches are designed to fit leading edge, hinged, or lift-off machine guards. Courtesy: AutomationDirectIDEM's INCH and MK1 series of miniature tongue interlock safety switches are designed to fit leading edge, hinged or lift-off machine guards. With a 16.5mm to 18mm or 16.5mm to 22mm mounting profile, rotating heads with dual actuator entry and force guided normally-closed contacts, switches are available with plastic or stainless steel housings and with M16, M12 quick disconnect or half-inch NPT threaded connections. HC series shaft hinge interlock switches feature solid or hollow shafts and two closed slow action contacts or one normally-open contact and one closed slow action, make before break contact.
AutomationDirect
www.automationdirect.com
AutomationDirect is a CSIA member as of 8/17/2015
