Integrated programming software
RSLogix v16 programming software allows GuardLogix users to control multiple axis robot applications. It features user-defined add-on instructions; and integrated drives configuration for faster setup, improved accuracy and easier drive maintenance. Robot control allows users to manage material handling, processing equipment and robot with one architecture.
RSLogix v16 programming software allows GuardLogix users to control multiple axis robot applications. It features user-defined add-on instructions; and integrated drives configuration for faster setup, improved accuracy and easier drive maintenance. Robot control allows users to manage material handling, processing equipment and robot with one architecture. Add-on instructions allow object-oriented programming using code encapsulated in pre-validated modules.
Rockwell Automation : www.ab.com
