Integrated Dress pack model added to mid-size robot family
With cables and hoses protected in the upper arm the IRB 2600ID shortens cycle times 15%, with lower operational costs, simplified programming
SOURCE: ABB Robotics/Zycon
02/21/2011
ABB IRB 2600ID RobotABB Robotics has added an Integrated Dress pack (ID) model to its IRB 2600 range of mid-sized robots, introducing the 2m reach, 8 kg payload IRB 2600ID. The ID model, reportedly designed for arc welding, features a flexible conduit in its upper arm/wrist for routing the cables and hoses, fully integrating the process equipment with the robot. The integrated design allegedly provides a number of benefits including 15% shorter cycle times, lower operational costs and easier programming, along with the standard IRB 2600 family performance benefits such as superior speed, flexible mounting options, an increased work envelope and unmatched path repeatability. ABB is purportedly one of the few robot suppliers that offer a mid-size robot in both standard and ID models.
With the internally routed dress pack the movement of the hoses and cables is completely predictable, allowing the IRB 2600ID to operate at maximum speeds and simplifying off-line programming. Without needing to account for swinging cables when simulating robot systems, the time required for fine-tuning programs is minimized by up to 90%, enabling faster transitions from weld to weld. The ID design also reduces the exposure of cables and hoses to weld splatter and other sources of overall wear, reducing replacement costs by 75% and saving up to three production stops per year. With completely predictable motion the IRB 2600ID is able to work in narrow spaces and around parts of a complex geometry on which the dressing could otherwise catch.
“The current trend in industrial robotic design is for process equipment to be fully integrated with the robot,” said Joe Campbell, vice president of the ABB Robot Products Group in the US. “This first IRB 2600ID model responds to the need our arc welding end-users have for a low maintenance, high performance robot that is easy to program and is incredibly nimble.”
With its compact design, and without loose hoses and cables, the IRB 2600ID allegedly has a very small footprint with a swing base radius of only 337mm and a base width of only 511mm. For arc welding the reduced risk of interference with other robots allegedly allows for productive, high-density installations with 50% more robots, and up to 50% higher output from a production cell. With the slimmer arm and smaller footprint, the IRB 2600ID can purportedly enter very narrow spaces and easily take on challenges such as circular welds without compromising on quality or speed.
ABB Robotics
www.abb.com
ABB
- Edited by Gust Gianos, CFE Media, Control Engineering, www.controleng.com
