Insulated coil boxes
Insulated coil boxes for room-by-room temperature control.
By RAE Corporation June 28, 2016
Insulated coil boxes for room-by-room temperature control. Where temperature is controlled on an equipment level, the RAE Coils Insulated Coil Boxes are capable of controlling temperatures on a per-room basis. This equipment is ideally designed for use in pharmaceutical processing, food storage, healthcare, and high-rise building applications. RAE Coils Insulated Coil Boxes can be used to control temperatures by room or by floor in heating, cooling, or dehumidification systems.
RAE Corporation
www.RAECorp.com
