Instruments & Controls
08/09/2004
IR-to-TC converter
OSM101 infrared-to-analog converter module is a portable, miniature, low-cost, battery-powered unit that converts noncontact infrared energy to a compensated K-type thermocouple output. It operates with thermocouple metering, display, or recording devices. Unit uses laser circle/dot sighting for ease of aiming. Features include adjustable emissivity and low battery indicator.
Omega Engineering, Inc. , omega.com , Write 319 on PE card
Multifunction psychrometer
RH350 superheat psychrometer is designed for HVACR, mold prevention, and plant maintenance applications. Instrument features a large display, which indicates relative humidity (rh); ambient air temperature; and either dew point, wet bulb, or external temperature. Memory stores up to 99 data points. Functions include date-and-time, minimum, maximum, and average readings.
Extech Instruments , extech.com , Write 320 on PE card
Panel flow display
M750 display unit/register accepts inputs from flowmeters, orifice plates, and vortex flowmeters. Unit indicates instantaneous flow rate as well as totalized flow. Instrument can be configured with single isolated 4%%MDASSML%%20 mA retransmission pod or a pair of normally open (NO) alarm relay pods. Alarms can be automatic or manual reset.
Spirax Sarco, Inc. , spiraxsarco.com/us , Write 321 on PE card
Fiber optic controller
Series 00 multichannel fiber optic controllers reduce excessive wiring for multiple fiber applications with a single cable. Controllers are compact, mechanically robust, and available in 2, 4, 6, and 8-fiber DIN-rail mountable models. Units feature LCD operator interface that rotates 180-deg electronically for mounting and application versatility.
ifm efector Inc. , ifmefector.com , Write 322 on PE card
Fiber optic tester
XC-8513 dual wavelength optical time domain reflectometer (OTDR) measures both fibers of a duplex fiber optic cable automatically with one connection. OTDR examines fiber optic systems to troubleshoot fiber segments, including the fiber and connectors at each end.
Megger , megger.com , Write 323 on PE card
