Instruments & Controls
Dual panel meter with math
PAXDP dual process input meter allows users to monitor, scale, and display two, independent input sources, perform high-speed math functions on the input values, and display the results. With optional plug-in cards, the meter can generate outputs that include alarm triggering, retransmission of analog signal, or data via many industrial networking protocols.
Red Lion Controls, Inc. Write 306 on PE card
Wireless I/O
XANT and N4ANT wireless I/O systems include transmitter, receiver, and antennae and associated enclosures. Transmitter/receiver system uses spread-spectrum frequency hopping with typical inplant range of 600_1000 ft. XANT is the explosion-proof system with cast aluminum enclosure that includes integral wire-sealing chamber. N4ANT is rated NEMA 4X for any industrial areas that require protection.
Phoenix Contact Inc. Write 307 on PE card
Temperature controllers
Broad line of high-accuracy temperature controllers offers many types and sizes. Controllers feature accuracy of1/ 16 _
Precision Digital Corp. Write 308 on PE card
Bench-top thermometers
MDSi8 and MDSSi8 bench-top digital thermometers are available in single and 10-channel models. Meters feature a portable, rugged, metal case with tilting handle and a programmable color display with larger-than-normal digits. Universal sensor input on single-channel units is programmable to accept standard thermocouples, RTDs, voltage or current signals. Options include RS-232/485 and Ethernet communications, analog output, and alarm relays.
Omega Engineering, Inc. Write 309 on PE card
I/O modules
1794-IB32 and 1794-OB32P 32-point I/O modules are designed for I/O installations where more than 128 I/O points are required in a single location or panel. Modules save panel space by reducing the number of modules required. The 1794-IB32 is a 24-Vdc sink input module; the 1794-OB32P is a 24-Vdc protected-source output module.
Rockwell Automation Write 310 on PE card
