Inspection lighting equipment
A series of inspection lighting fixtures and carts is specifically designed for use in hazardous, industrial and commercial work areas.
A series of inspection lighting fixtures and carts is specifically designed for use in hazardous, industrial and commercial work areas. Available in 4- and 8-foot lengths, the fixtures are constructed from a cold-rolled steel one-piece housing and finished with a Specular polished reflector. They’re suited for paint spray area inspections. Two- and three-fixture inspection light carts provide portable lighting solutions for various applications. Light fixtures are mounted either vertically or horizontally and are attached with swivel mounting brackets.
LDPI Inc.
www.ldpi-inc.com
