Industrial network integration improves productivity
Selecting industrial networking protocols, industrial Ethernet included, helps improve production efficiency and quality, with enterprise connectivity. Connectorized networking decreases repair time to minutes from hours.
Bob Kollmeyer
08/15/2012
To help manufacturers accommodate evolving networking requirements, such as decentralization of control, integrated diagnostics, and simplified maintenance, network protocols integrate with industrial equipment and control systems to communicate crucial status updates and production data. A powerful industrial tool to streamline manufacturing production is reliable, enterprise-wide connectivity, providing the highest level of visibility, control, and flexibility—helping to increase productivity and reduce operating costs.
With the migration away from point-to-point connection, advanced networking architectures ensure connectivity, collaboration, and integration from the device level to enterprise business systems. By examining the performance capabilities and application suitability of industrial networks (such as DeviceNet, Profibus, and various Ethernet protocols), manufacturers can select the ideal networking solution for continuous, complete control over all production components.
Proactively enhancing networking capabilities provides advantages ranging from complete process efficiency and remote access to system controls, to faster response times, to factory floor events and minimized downtime, to name a few. By maximizing production control, enterprise connectivity can improve product quality, customer satisfaction, and company profitability.
When choosing a networking solution, users must understand the individual communication requirements as well as any environmental challenges present in each application. Evaluating the performance capabilities, features, and characteristics of industrial protocols can assist manufacturers in selecting the ideal networking solution for critical communication needs.
DeviceNet
Supporting up to 64 nodes and virtually unlimited amounts of I/O, DeviceNet is compatible with a wide range of industrial manufacturing products, connecting to nearly any device and allowing stations to be easily added to existing operations. Courtesy: TuDeviceNet is a low-cost communication protocol that connects and serves as a communication network between industrial controllers and I/O devices, with each device serving as a node on the network. The protocol is used for connecting and networking a wide variety of industrial devices, including limit switches, sensors, valve manifolds, motor starters, process sensors, bar code readers, variable frequency drives, panel displays, and operator interfaces. DeviceNet is based on the Controller Area Network (CAN) broadcast-oriented communication architecture, which ensures that the highest priority messages always have access to the bus in the event of a data collision. With DeviceNet, these priorities are further defined, giving top priority to I/O messages and lower priority to configuration messages.
Capable of operating on a client/server and a master/slave basis, DeviceNet accommodates diverse communication needs. With client/server, the network provides a convenient way to interconnect programs that are distributed efficiently across different locations. It also allows peer-to-peer data exchange, where a node can initiate communication with other nodes or peers. Through master/slave operation, the master node initiates all communication with all other nodes responding to the master’s request. DeviceNet is best suited for collecting and managing I/O data that machine and process control systems rely on.
Supporting up to 64 nodes, DeviceNet networks offer virtually unlimited amounts of I/O. The bus uses a trunkline-dropline topology, which allows bus power and communication to be supplied on a single cable. DeviceNet is compatible with a wide range of industrial manufacturing products, enabling it to connect to nearly any device and allow stations to be easily added to existing operations. Further, by permitting direct connections to control devices, DeviceNet eliminates point-to-point wiring, which improves communication between devices as well as provides critical device-level diagnostics not easily accessible through point-to-point I/O interfaces.
DeviceNet is connected to programmable logic controllers (PLCs) to obtain and transmit messages to the network via these PLCs, which are typically programmed via PCs. These stations are designed to transfer data from industrial devices to the controllers, as well as to perform different control functions, such as PID loops, start/stop motors, turn indicators ON and OFF, position valves, and more. Plus, for enhanced flexibility, devices connected to DeviceNet stations can also be hot swapped—removed and replaced without affecting other operations connected to the station. ODVA is the governing organization for this protocol.
Profibus
Profibus is an industrial network protocol that connects field I/O devices in order to eliminate hardwiring. Profibus is designed to increase device-level diagnostic capabilities while maintaining high-speed communication between devices. Profibus-DP, a version of Profibus based on the RS-485 serial data transfer standard, is ideal for use in factory automation and machine control solutions. RS-485 allows multiple devices (up to 32) to communicate at half-duplex on a single pair of wires, at distances up to 1200 meters (4000 ft).
A Profibus-DP network supports up to 126 nodes with virtually unlimited I/O, with power and communication provided via separate cables, allowing easy segmentation of the power structure to avoid overloading. Plus, network length and the number of nodes can easily be extended using a variety of repeater products. This enables control of manufacturing and other processes over a wide area—such as the factory floor—from a central computer control station.
When selecting a network protocol, speed is a critical factor. Profibus is capable of running data rates as high as 12 Mbaud. However, when it is used at high speeds, the cable drop length from the trunk to a node is severely limited. For example, when manufacturers are using Profibus at 12 Mbaud, nodes must be directly connected to the trunk, with no drop length allowed.
In addition to providing the communication capabilities required for machine control applications, Profibus is also well suited for process applications and hazardous area locations. When implementing this network solution in challenging industrial environments, Profibus-DP can be directly connected to I/O devices in classified areas, resulting in a significant savings on barriers and wiring. Further, Profibus-PA, another version of Profibus, operates as an extension from the Profibus-DP system that allows network communication directly in hazardous areas. PI North America (which also offers an Ethernet protocol, Profinet) is the regional governing organization for Profibus.
Ethernet
An Ethernet TCP/IP network can extend communication plant-wide, allowing users to connect to a corporation’s worldwide network via the Internet. Courtesy: TurckThe Ethernet physical layer was developed with the primary purpose of conveying large amounts of information. Applied first to office-level networks, where multiple clients use the network to share information, Ethernet has expanded beyond traditional usage to the plant floor, especially with the advent of industrial Ethernet protocols (such as EtherNet/IP from ODVA). Ethernet communications can be used for industrial data collection, transmission, and monitoring.
When the EtherNet/IP protocol is used over the Ethernet physical layer, the exchange of data is based on the producer/consumer model. This means that a transmitting device produces data on the network and multiple receiving devices consume this data simultaneously. Traffic generated during this data exchange can include input/output data and status updates produced by a remote device for consumption by one or more programmable controllers. Data collected and controlled via EtherNet/IP can use an unacknowledged method of sending information between devices on a network, which means that data delivery is not guaranteed. Therefore, to ensure delivery, a higher layer must be implemented prior to data transfer.
Transmission Control Protocol/Internet Protocol (TCP/IP) provides a set of services so devices may communicate over an Ethernet network. With the increased prevalence of Internet and intranets for internal information distribution, TCP/IP has grown and has been transported to all major computer operating systems. A typical example of when a manufacturer would implement an Ethernet TCP/IP network is to extend communication plant-wide to connect to a corporation’s worldwide network via the Internet. Ethernet TCP/IP can take advantage of Ethernet’s high capacity for data management to perform a wide variety of tasks, without requiring a high level of determinism or repeatability for message response time. Common TCP/IP applications include program maintenance, data transfer, web page retrieval, supervisory control, connectivity for operator interfaces and events, and alarm recording.
Faster connectivity
Network protocols connect the office with the plant floor, providing secure, seamless interoperability among manufacturing enterprise networks for constant internet and enterprise connectivity. Courtesy: TurckAs plants expand and information is required to move across greater distances, at faster speeds, and in larger quantities, maintaining reliable enterprise connectivity is necessary for continued overall production. Since network protocols connect the office with the plant floor, providing secure, seamless interoperability among manufacturing enterprise networks enables constant Internet and enterprise connectivity. Implementing a complete, end-to-end networking solution provides a wide range of benefits, including a lower overall total cost of ownership (TCO), a higher return on investment (ROI) due to real-time visibility and flexibility, reduced network maintenance, and decreased labor costs.
Connectorized networks allow for modularity, which traditional wiring methods cannot provide, as an electronic control system cannot be easily modified using conduit and individual wires. In contrast, modular networks can be engineered and modified quickly and easily—significantly reducing design and manufacturing time.
One immediate advantage to enterprise connectivity is the reduced cost of installation and maintenance. With their plug-and-play simplicity, implementing facility-wide networking solutions is accomplished significantly faster than traditional wired connections. The time required to strip the jacket, prepare the conductors, feed the cable through a gland, insert the wires into the terminals, and tighten the cable gland can be as much as 5 to 10 min. per connection. This process can become even more complex and time-consuming when traditional wiring is being installed in physically demanding locations. Plus, with the elimination of wiring errors, manufacturers experience greater savings by limiting production downtime and maintenance to ensure continued performance.
Further, one of the most beneficial features of connectorized networks is the minimal repair time, completed in minutes rather than hours, as any section of a network or I/O cable can be replaced in seconds. Fully connectorized networks essentially eliminate signal wire troubleshooting and repair. Providing constant access to real-time data improves plant operations by providing diagnostic information of any problem faster, improving uptime with corrective action capabilities. Additionally, by delivering faster, less costly plant upgrades, expansions, and changeouts, connectivity promotes enterprise growth and plant efficiency.
Industrial networking future
Connectivity is becoming the foundation for enterprise efficiency and productivity, as the demand for constant communication grows. With advanced protocol capabilities, manufacturers can implement the ideal networking solution to achieve, fast, secure, and reliable data transfer factory-wide.
- Bob Kollmeyer is business development manager—networks, Turck. Edited by Mark T. Hoske, content manager CFE Media, Control Engineering and Plant Engineering, mhoske(at)cfemedia.com.
Network products Channel on Control Engineering
System integration and networking articles
