Industrial laser scanner for anti-collision, presence detection
The TiM310 field detection laser scanner from Sick is designed for anti-collision and presence detection and has a 270° scanning range for field detection applications.
Sick’s TiM310 field detection laser scanner is designed for anti-collision and presence detection. The TiM310 is an industrial-grade laser scanner that is enclosed in a compact aluminum housing with an IP 65 enclosure rating.
The TiM310 is approximately the size of a baseball and weighs about a third of a pound. The TiM310 features a 270° scanning range that is suitable for simple, discrete I/O and field detection applications in the robotics, logistics and building automation industries. Its small size, 3W power consumption and large detection range make it particularly suitable for small vehicles.
With 16 preconfigured fields, the TiM310 can be configured in less than five minutes, which reduces installation time and costs. A “Touch and Teach” button further simplifies setup since no manual computer settings are required. For complex fieldset shapes or quick in-field replacements, the easy-to-use SOPAS configuration tool can be used.
Sick
www.sickusa.com
See other Control Engineering sensing products.
