Index of Finalists
11/01/2008
Company
Product
Category
Page
A.W. Chesterton
Sealing technology
Fluid Handling
58
Adobe Systems Inc.
CAD, PDF file sharing software
Productivity & Training Software
53
APC by Schneider Electric
Scalable UPS
Electrical Power
40
Apprion
Wireless infrastructure management
Automation & Control
45
Atlas Copco
Oil-injected compressors
Compressed Air
57
Baldor
Mounted roller bearing
Power Transmission
60
Bentley
Electrical CAD software
53
Bessamaire
Evaporative cooler
HVAC
55
Big Ass Fans
Fan
HVAC
55
BizWare Direct Inc.
ERP, MES software package
52
Bosch Rexroth Corp.
Production system
Manual Material Handling
63
Cognex
Compact machine vision system
44
Compare
Variable-speed air compressor
Compressed Air
57
Cooper Lighting
Luminaire
Lighting
59
Cutsforth, Inc.
Generator brush holder system
Electrical Power
40
DL Manufacturing
Dock light
Lighting
59
DL Manufacturing
Under-leveler insulation kit
Construction, Buildings & Grounds
56
DLI Engineering
Remote condition monitoring system
Maintenance Software
52
Donaldson Tori
Torit PowerCore dust collectors and filters
Environment, Safety & Health
54
Dyadem
Quality, risk management software
53
Eaton
Managed, switched power distribution
Electrical Power
41
Eaton
Single-phase UPS
Electrical Power
41
Eaton
LV power circuit breakers
Electrical Power
42
Eaton
Automatic transfer switch family
Electrical Power
42
Eaton
Panelboards for busway connections
Electrical Power
40
Eaton
Panelboard with neutral grouping
Electrical Power
42
Eaton
Solid-state overload relay
Electric Motors, Drives & Controls
47
Electro Industries/Gauge Tech
Power, energy meter with I/O
Electrical Power
42
Emerson Industrial Automation
Roller bearing
Power Transmission
60
Emerson Motor Company
Horizontal motor for oil, gas
46
Emerson Process Mgmt, Micro Motion Div.
Two-wire Coriolis flowmeter
Instrumentation
47
E-MON, LLC
Wireless three-phase kWh meter
Electrical Power
41
Equipois Inc.
zeroG4
54
ERIEZ
FinesSort
Material Handling Systems
61
Exair Corp.
Compressed air nozzle
Compressed Air
57
Extech Instruments Corp., div. of Flir Corp.
Compact thermal imaging camera
Maintenance Tools & Equipment
48
Farr Air Pollution Control
FDC Dust Collector Controller
54
Ferraz Shawmut
Fuse-type panelboard
Electrical Power
40
FLIR Systems, Inc.
Infrared cameras
48
FLIR Systems, Inc.
Infrared camera
49
FLIR Systems, Inc.
Infrared camera
49
FLIR Systems, Inc.
Infrared camera
50
FLIR Systems, Inc.
Infrared camera
50
Fluke Corp.
Thermal imagers
48
Gardner Denver
HeliFlow Industrial Series 616 and 624
62
Garlock Sealing Technologies, Klozure div.
Bearing isolator
Maintenance Products
51
Gates Corp.
Coupling
Fluid Handling
58
Gates Corp.
Hydraulic hose sleeving system
Fluid Handling
59
GE Consumer & Industrial
Low-voltage power circuit breaker
Electrical Power
40
GE Fanuc Intelligent Platforms
HMI/SCADA visualization software
44
Maintenance software
51
Goodway Technologies, Corp.
Foam cleaner for cooling towers
49
Gorbel Inc.
Jib crane
63
Harrington Hoists, Inc.
NER/ER Electric Chain Hoists
61
Hawk Measurement
Sonar level measurement system
Instrumentation
47
Hilti Inc.
Hilti VC20-U + VC 40-U vacuums
55
Hitachi
Large capacity ac drive
46
Honeywell Process Solutions
Inventory tracking and tracing software
53
Infor
Asset sustainability software
51
Inpro/Seal
Shaft sealing system
50
IRISS Inc
Infrared inspection window
50
IRISS Inc.
Inspection viewing window
51
ITT Corp.
Knife gate slurry valve
Fluid Handling
59
ITT Corp.
ANSI process pump
Fluid Handling
58
JLG Industries Inc.
Portable lift
62
Lenze-AC Tech
Servo drive with embedded software
47
Life Cycle Engineering
Leadership skills training
53
Liftow
Lock-out Box
55
Liftow
Forklift level indicator
62
Liftow
Lift Truck Log
61
Ludeca, Inc.
Vibration analyzer
49
Miller Fall Protection
Miller TurboLite Personal Fall Limiter
54
Misumi USA, Inc.
Axis stages
62
Molex, Inc., Automation and Electrical Products Div.
DeviceNet diagnostic monitor
43
IP67-rated EtherNet/IP I/O block
45
Ethernet/serial communication modules
46
Remote scanner for DeviceNet
45
National Instruments Corp.
Cameras for inspection, machine vision
43
Enhanced design software
52
Neptune Research Inc.
Composite pipe-reinforcing wrap
50
New Pig Corp.
Containment pallet
Fluid Handling
58
New Pig Corp.
Drum lid
48
New Pig Corp.
Funnel
50
New Pig Corp.
Leak diverter
51
New Pig Corp.
FAT MAT Super-Absorbent Mat
54
New Pig Corp.
Containment tray
62
New Pig Corp.
PIG 5-Gallon Latching Pail Lid
60
New Standard Institute
Belt, chain drive training
52
Operation Technology
Electrical analysis software
Electrical Power
42
Orion Energy Systems Inc.
Light Pipe
Lighting
59
Parsec Automation Corp.
Real-time productivity software
53
ProSoft Technology
Master, slave I/O for Profibus DP
43
Quick Fitting Inc.
Ball valves
Fluid Handling
59
Quick Fitting Inc.
Push valves
Fluid Handling
58
Ramsay Corp.
Test for CNC operators
52
Rite-Hite Corp.
Barrier system
56
Rockwell Automation
Safety I/O module
43
Rockwell Automation
Modular managed switch
44
Rockwell Automation
PAC for SIL applications
45
Rockwell Automation
Compact PAC for small applications
44
Rockwell Automation
Asset management software
52
Rytec Corp.
Rolling grille door
56
Schneider Electric
Panelboard for lighting applications
Electrical Power
41
Schneider Electric
Remote monitoring power meter
Electrical Power
41
Schneider Electric
Low voltage MCC
46
Schneider Electric
Motor management system
47
Schneider Electric
Simplified pushbutton spring clamp
43
Schneider Electric
Compact controller for harsh environments
44
Siemens Energy & Automation Inc.
Arc-resistant LV switchgear
Electrical Power
41
Wireless mobile HMI
43
45
Switch-mode power supply
44
Distributed I/O module with Profinet
46
Sopogy, Inc.
Solar concentrator
Electrical Power
42
Sperian Protection
VeriPRO
54
Spirax Sarco Inc.
Steam separator
Fluid Handling
58
Stealth Computer Corp.
Widescreen industrial LCD monitor
45
Streamlight Inc.
Rechargeable LED flashlights
51
Sullair Corp.
Rotary-screw air compressors
Compressed Air
57
The Raymond Corp.
Harsh environment pallet trucks
63
The Raymond Corp.
iWarehouse Fleet Optimization System
61
Topper Industrial, Inc.
TRANS4MER CART
60
Hydraulic Mother Cart
61
Engine Block Conveyor Cart
61
Corral Cart with Self-Elevating Dollies
62
TorcUP Inc.
Pneumatic wrench
49
Torque Gun Co. LLC
Torque gun
48
Toshiba International Corp.
IGBT-based UPS
Electrical Power
40
Adjustable speed drive
46
Toyota Material Handling, USA, Inc.
Toyota ac electric tow tractors
60
Toyota 8-Series reach truck
60
UE Systems Inc.
Ultrasonic inspection system
48
UltraTech International Inc.
Magnetic rack protection
56
Ultra-ADA Pad, Cas-in-Place Model
55
Vaisala
Dewpoint transmitter
Compressed Air
57
Vibralign Inc.
Laser shaft alignment system
49
Victaulic
Vortex Fire Suppression System
55
Zoneworks Flexible Industrial Barriers
Barrier curtains
56
