Incremental encoders
DRS61 CoreTech 60-mm diameter incremental encoders allow users to program the number of lines from 1 to 8,192, as well as the width of the zero pulse using a simple USB connection and programming software. Their flexibility allows users to use a single type of encoder that can be programmed at any time for most applications.
DRS61 CoreTech 60-mm diameter incremental encoders allow users to program the number of lines from 1 to 8,192, as well as the width of the zero pulse using a simple USB connection and programming software. Their flexibility allows users to use a single type of encoder that can be programmed at any time for most applications. The encoders are available in face-mount flange, servo flange, blind or through-hollow-shaft with connector or cable outlet, TTL or HTL interface configurations. Interchangeable collets are available for encoders with hollow shaft configurations in diameters from 6 to 15 mm, and 0.25, 0.375 and 0.50 inches. Opto-ASIC with chip-on-board technology provides maximum encoder reliability, and automatic light regulation facilitates long LED life. Applications include machine tools, textile machines, woodworking machines and packaging machines, among others.
Sick Stegmann
www.stegmann.com
