Hydraulically-powered skidding system for heavy loads
The 300-ton and 500-ton capacity hydraulically powered Hydra-Slide heavy track skidding systems are for moving, loading or unloading all types of heavy loads.
The 300-ton and 500-ton capacity hydraulically powered Hydra-Slide heavy track skidding systems are for moving, loading or unloading all types of heavy loads. The systems include 50 feet of double track and four skid shoes. The push cylinders and all connecting hardware come packed conveniently in a steel toolbox for storage. The unique ratchet track design facilitates continuous movement and automatic resetting of push cylinders. Loads can be moved in either direction by simply repositioning the push cylinders.
Lifting Gera Higher
www.lgh-usa.com
– Edited by CFE Media. See more Oil & Gas Engineering products.
