Hybrid technology
The PGT23 intelliGAUGE from WIKA can be used in any application where the process pressure has to be indicated locally and at the same time signal transmission to a central controller or remote control room is needed. Through the combination of a mechanical measuring system and electronic signal processing, the process pressure can still be read, even if the power supply is lost.
The PGT23 intelliGAUGE from WIKA can be used in any application where the process pressure has to be indicated locally and at the same time signal transmission to a central controller or remote control room is needed. Through the combination of a mechanical measuring system and electronic signal processing, the process pressure can still be read, even if the power supply is lost. An additional measuring point for the mechanical pressure indication is no longer needed.
WIKA Instrument Corporation www.wika.com
