Hose fittings used for high-pressure applications
Spiral through the cover one-piece hydraulic fittings are used for high-pressure hose applications up to 6000 psi on heavy construction equipment.
Spiral through the cover one-piece hydraulic fittings are used for high-pressure hose applications up to 6000 psi on heavy construction equipment. No brazed or welded joints are used, which greatly reduces potential leak paths and the chance of product failure. The fittings incorporate a stress relief design and offer high impulse life.
Eaton Corp., Aeroquip Div.; www.aeroquip.com
TO VOTE, WRITE 132 ON BALLOT
For more information, circle 418 on card
