High-speed camera
The HiSpec low-light high-speed camera has a monochrome ASA rating of 2,500 and can capture images in detail without requiring high-intensity lighting.
The HiSpec low-light high-speed camera is designed for use in industrial and research applications. With a monochrome ASA rating of 2,500, it can capture images in detail without requiring high-intensity lighting. The camera can record up to 500 frames per second at a resolution of 1,280×1,024 pixels; it’s capable of up to 113,000 fps at reduced resolution, and captures high-speed recordings at 1.3 megapixels under normal lighting conditions. A gigabit Ethernet interface allows the user to operate multiple cameras from any standard Notebook /PC over a distance of 100 meters.
Fastec Imaging Corp.
www.fastecimaging.com
