High-frequency analog IO modules
High-frequency Snap-Airate-HFi rate input and Snap-AOD-29-HFi pulse-width modulation (PWM) modules by Opto 22 support testing, simulation, and other high-speed applications.
10/15/2013
High-frequency SNAP-AIRATE-HFi rate input and SNAP-AOD-29-HFi pulse-width modulation (PWM) modules by Opto 22 support testing, simulation, and other high-speed applications. Courtesy: Opto 22Opto 22 introduced two new high-frequency analog Snap I/O modules, the Snap-Airate-HFi rate-input module and the Snap-AOD-29-HFi module. The Opto 22 Snap-AOD-29-HFi module has pulse-width modulation (PWM) and time-proportional output (TPO). These modules are designed for test engineers, technicians, and others working with high-speed machinery, equipment test beds, and other applications that monitor high-frequency analog signals and rapidly switch digital outputs in response to a changing analog value. Both modules are used with Opto 22’s Snap PAC System, which includes programmable automation controllers (PACs) and Ethernet-based I/O systems.
The analog input module connects to TTL, CMOS, and open-collector outputs, and is typically used for high-speed (up to 500 kHz) pulse scanning. The module has two isolated channels, each of which can be configured for a 0.1-second measurement interval with an input range of 20 Hz to 500 kHz, or a 1-second measurement interval with an input range of 2 Hz to 500 kHz. For each channel, 9 V dc is provided internally for devices with open-collector outputs, making it unnecessary to provide a pull-up voltage supply.
The analog output module sends pulse-width modulated outputs to high-frequency transducers and can be used, for example, with test bed applications that simulate tachometer outputs. Each of the module’s two optically isolated channels can switch 100 mA of load current ranging from 2.5 V dc to 24 V dc (supplied externally), over a period range of 10 microseconds to 64.25 seconds (0-100 kHz).
Both modules are optically isolated from the equipment and devices they connect to, as well as from other analog, digital, and serial modules on a shared I/O rack.
Opto 22
www.opto22.com
- See more Control Engineering I/O system and module products.
