High-dynamic range camera
The AD-081CL high dynamic range (HDR) camera features a dual-CCD design with two standard ICX204AL 1/3-inch monochrome progressive scan sensors mounted to a custom-designed optical prism.
The AD-081CL high dynamic range (HDR) camera features a dual-CCD design with two standard ICX204AL 1/3-inch monochrome progressive scan sensors mounted to a custom-designed optical prism. The prism-based design enables the camera to simultaneously capture two channels of 30-fps video, with each channel having 1024 x 768 resolution, eight- or 10-bit pixel depth, and precise alignment to the same optical axis. Typical HDR applications include inspection tasks where incident light or bright reflections are present, such as LED inspection, welding, and various types of lighting or glass inspections.
JAI Group
