High-density, 16-point I/O modules
The 16-point I/O ribbon-cable modules offer compact solutions for streamlining control-to-machine wiring. With the flat ribbon cable, the modules facilitate the use of pre-wired assemblies to minimize wiring time and errors.
09/28/2009
16-point IO modules
solutions for streamlining control-to-machine wiring. The DIN-rail mount
modules feature 16 inputs (750-1400), 16 outputs (750-1500) or 8 inputs/8
outputs (750-1502) and an HE10 ribbon cable interface. With the flat ribbon
The 16-point I/O modules are compatible with WAGO's
interface boards, ranging from an LED-equipped 120 Vac to 24 Vdc input
interface board, to a 3.75-inch-wide, 16-channel relay interface board
featuring 5 mm plug-in relays. For additional voltage flexibility, the 16-point
I/O modules can pair with select interface boards to connect to any voltage up
to 120 Vac at 6 A. All 16-point I/O modules carry onboard LEDs for status
indication and use CAGE CLAMP spring pressure terminations for field
connections.
WAGO
www.wago.us
