High bay LED light fixture
GAU-HB-200W-LED-WP high bay LED light fixture is constructed of copper free aluminum alloy powder coated for added durability and corrosion resistance.
Larson Electronics’ GAU-HB-200W-LED-WP high bay LED light fixture is constructed of copper free aluminum alloy powder coated for added durability and corrosion resistance. The 12 light emitting diodes are protected by a polycarbonate lens and produce 110 lm/W. Constructed with CREE LEDs, the fixture has a heat dissipating design in conjunction with LED technology that helps achieve a 50,000-hour lifespan. This light is multi-voltage capable and can be operated with 100-277 V AC without any need for a ballast. The GAU-HB-200W-LED-WP can be mounted by a ¾ in mounting hub or by an included eyelet for chain hanging.
Larson Electronics
Larsonelectronics.com
