Heavy-duty pump lubrication
Pretested and prequalified API 610 and 614 lubrication systems provide customized reliability for heavy-duty centrifugal pump and compressor applications.
Pretested and prequalified API 610 and 614 lubrication systems provide customized reliability for heavy-duty centrifugal pump and compressor applications. Designed to exacting customer specifications, each of these large, skid-based support systems is engineered via a global data network. The largest unit measures 11 X 40 ft and is built to requirements set by individual applications and API standards. Reliability is verified prior to shipment by a wide variety of tests, including operational, hydraulic, electrical, and functional.
John Crane
www.johncrane.com
Circle 252
