Heat transfer fluid replaces glycol
GR-40 biodegradable heat transfer fluid can directly replace ethylene or propylene glycol without system modification in applications from -40-350 F. Heat transfer efficiency is 35-55% better than ethylene glycol and 60- 150% better than propylene glycol.
Paratherm Corp.
