Heat exchanger
Remove heat from IT racks before it enters the data center with the Liebert XDR rear-door heat exchanger from Emerson Network Power. The microchannel heat exchangers are mounted in a moveable door, which is fixed to a frame attached to the rear of the rack. The exchanger relies on server fans for hot air movement across a cooling coil, which uses a pumped refrigerant that is 700% more efficient...
12/01/2009
Remove heat from IT racks before it enters the data center with the Liebert XDR rear-door heat exchanger from Emerson Network Power. The microchannel heat exchangers are mounted in a moveable door, which is fixed to a frame attached to the rear of the rack. The exchanger relies on server fans for hot air movement across a cooling coil, which uses a pumped refrigerant that is 700% more efficient at removing heat than water. The exchanger can cool up to 20 kW of rack load and the door on the exchanger opens 100 degrees.
www.liebert.com #3
