Hazardous location signal light with audible horn
The HAL-TL-5X10W-C-PA is a hazardous location LED signal stack light equipped with an audible horn for use in hazardous environments where explosive and flammable gases, vapors, and dusts may occasionally be present.
The HAL-TL-5X10W-C-PA is a hazardous location LED signal stack light equipped with an audible horn for use in hazardous environments where explosive and flammable gases, vapors, and dusts may occasionally be present. The signal light is equipped with five 10 watt LED lamps, producing an amber, red, blue, green, and white light output. This unit carries a T3 temperature rating, is weatherproof, dust-proof, NEMA 4X rated and marine rated for wet environments.
Larson Electronics
www.larsonelectronics.com
