Handle heavy-duty drums
Model 6100 drum handling, fork lift attachment has a carbon steel frame and exclusive clamping mechanism for handling loads up to 1000 lb.
Model 6100 drum handling, fork lift attachment has a carbon steel frame and exclusive clamping mechanism for handling loads up to 1000 lb. Compatible with most fork lifts, the device is an efficient, safe, and reliable unit capable of lifting, transporting, and palletizing 30-55-gal. drums. It attaches to a single fork.
Drum Runner Material Handling Co.
www.drumrunner.com
Circle 254
