Getting a good grip
Problem: How can I get a comfortable grip on an adjustable wrench? Solution: Take a piece of shrink tubing often used on wires and cables and cut it a bit shorter than the length of the wrench handle.
Solution: Take a piece of shrink tubing often used on wires and cables and cut it a bit shorter than the length of the wrench handle. Use a heat gun to shrink the tubing onto the handle. A comfortable grip results.
Contributor: Ron Hardison, Maintenance Technician, AFG Industries, Victorville, CA
