Gearbox lubricant
A new gear oil series is engineered to deliver long-lasting wear and corrosion protection for gearboxes.
Mobilgear 600 XP is engineered to deliver long-lasting wear and corrosion protection for gearboxes. Surpassing specifications such as Flender BA Table 7300 A, DIN 51517 Part 3 and AGMA 9005 E02, the lubricant helps control micropitting and is designed to reduce the formation of oil degradation byproducts that can lead to frequent oil changes. It complies with the compatibility requirements of many commonly used standards, including Flender QMC.BO Revision 9.
ExxonMobil Corp.
www.exxonmobil.com
